Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: LCD cable using RJ-45 network cable?
    Low Bitrate com2soft's Avatar
    Sep 2006
    Can I use RJ-45 network cable for wiring to my LCD (it is 8-pin I counted). How long can it run (VGA signal)?
    Sep 2006
    Quote Originally Posted by com2soft View Post
    Found that it may work. see pic from another product.
    as told, one of its rj45 is the VGA cable.
    Nov 2006
    Northamptonshire (UK)
    i had one of these in my car and found it to be prety lousy, anyway thats really besides teh point, the picture above modulates teh signal it isnt just an rj45 connector connected to the vga port then the little box that the rj45 cable and the monitor plug into decodes it at the other end,
    my experience was that doing it this way made the fonts and edges of windows a bit blury but that was only my opinion, what you are asking to do is a viable option, and would most liely work better than this machine above and the cat5/6 ethernet cable is probably a lot better quality than most cheap vga cables out there anyway!
    not to ask a silly question but is there any reason you would want to do it using rj45 connectors and ethernet cable rather than just buy an inexpensive vga extension cable?
    Variable Bitrate gameboy's Avatar
    May 2005
    Elizabeth City, NC
    be sure to use sheilded cable...prob help with noise...attach the shield to the car at both ends...
    95 Mazda Protege LX
    Worklog
    Overall [Project Dead] 0%
    2003 Nissan Altima
    [XXXXXXXX--] 80% Planning
    [XX--------] 20% FABRICATION/INSTALLATION
    Worklog
    Sep 2006
    Quote Originally Posted by gameboy View Post
    yes, shielded cat and shield rj45 plug should work better than cheap vga. these rj45 are rated at 1 giga bit in digital.
    and the product above shown to me that it should work.
    Newbie Black_Sheep's Avatar
    Feb 2006
    Coxsackie, NY
    A good VGA to Ethernet converter like this one from Black Box seem to be more expensive then their worth for the distance your talking about. In a car the most distance you should need is 10 ft. People use the CAT 5 solution when they want to go 100 ft. or more. (This one goes up to 500 ft.)
    If you make something Idiot proof....
    The world will make a better Idiot.
    CarPC Progresss: Planning [x-------------------]
    Oct 2004
    NY
    yeah, unless your building one of those really huge streach limo jobs, a vga cable even at 15' should be fine....
    Sep 2006
    Quote Originally Posted by Black_Sheep View Post
    Item Code # List Price
    VGA Extender AC555A $149.99
    oh.. i see its distance now.
    Nov 2006
    I have one of the black box extenders witrh the ps/2 ports aswell i use it to access my server (in the cellar from my office upstairs) it does the job but it still has the same problem of not being great quality, this suits my needs just for the server however for dvd playback/navigation etc its not so great, however i think between us the general concensus is just to buy a vgacable form eBay or something
    Sep 2006
    Quote Originally Posted by screwc149 View Post
    The reason i want to use rj45 is because the vga cable is too fat and not easy to wire in my car. rj45 thickness is 5-6mm i recall. my lcd vga plug is also 8 pins.
    btw the above product may fit my need. it is "3-cable-system carputer" the guy told me. my concern solved running 3 rj45 from boot to my dash is easy for newbie like me
  1. AutoVision LCD cable?
    By the thomas in forum LCD/Display
    Last Post: 10-07-2007, 10:22 PM
  2. network cable to RCA video
    By CayenneRedV6 in forum LCD/Display
    Last Post: 02-23-2006, 10:00 PM
  3. LCD cable won't work
    By dudah85 in forum General Hardware Discussion
    Last Post: 07-18-2001, 10:35 AM
  4. What cable for the LCD to the trunk?
    Last Post: 05-09-2001, 04:36 PM
  5. lcd cable length extension?
    By newbie in forum General Hardware Discussion
    Last Post: 03-13-2000, 06:31 PM
