Results 1 to 6 of 6
Thread: Shockproof mount.
    Aug 2006
    Shockproof mount.
    Hi,
    Appreciate it very much if someone can let me know what is this thingy called? This photo is taken from the link provided by "Peoples".
    And, where can I buy this thingy.
    Thanks in Advance.
    Constant Bitrate Grimoire's Avatar
    May 2006
    Fayetteville, NC
    honestly, thos look like pool cue tips. The screw on type. Looks like someone just threw a screw in the wrong way....
    Thats how it seems to me anyway.
    Jan 2006
    Arrow
    a) theres no such thing as a shock proof mount
    b) if you want a decent mount use a couple of rubber band that are stretched - go and have a look at the antec p150
    from : http://www.silentpcreview.com/article272-page4.html
    Aug 2006
    If it's floating using a rubber band, I quess it will work in the normal PC Environment. But would it work, if it's being put inside the car?
    Nov 2006
    I saw these or something like them a long time ago. They should be for silencing a pc. More specifically from what I remember to attach the HD to the chassis. That way the rubber absorbs the vibration and helps quiet the pc. I was looking for stuff for building a HTPC, so try going down that avenue to see if you can find it. I tried a search but didnt put too much into. Good Luck!!
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    not sure what those are, but if your looking for shock proof mounts, take a look at RC vehicle shock absorbers...
    http://images.google.com/images?hl=e...=Search+Images
    with a little tweeking something can be made out of them... and as for shock, i have had no issues with shock. I've been on gravel roads, brick roads, messed up ghetto city roads,... my carputer is still going good.
    ~0okami.Digital
  1. Through Roof Mount XM Antenna
    By cherrybomb in forum General Hardware Discussion
    Last Post: 10-29-2010, 08:26 AM
  2. Dash mount screen in GM Chevy Tahoe
    By slushieken in forum LCD/Display
    Last Post: 06-19-2006, 04:31 PM
  3. LCD Roof Mount for Taxi - Options?
    By Traumahawk in forum LCD/Display
    Last Post: 07-03-2005, 04:16 AM
  4. snake mount
    By fretboard65 in forum General Hardware Discussion
    Last Post: 04-05-2005, 11:41 AM
  5. Replies: 0
    Last Post: 07-14-2003, 04:12 PM
