Why cant you connect it to the car electrical system? Fans dont need a regulated output, and will happlily run off 14.4v instead of 12v.
At present I'm putting together my new system, and at present the only thing I need 12v for is the fan. Anyone know where I could get a 5v on the prossess in a Pentium 233 MMX jobie.
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
(=========-) 99% complete
AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
All jammed in external CDROM drive case.
Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
Are you sure about this, as if the fan fails it all goes up in smoke. Althought I can't see any reason why unregulated wouldn't work fine, I might have to see what happens when I crank to engine however.
Works great. Do you think that all those people with fans on their amp enclosures have power supplies? Fans are suprisingly durable and should last you a fairly long time.
HU: Clarion 9575RZ
EQ: Clarion 90EQ
Amps: Dei 1100d and DEI 400
Front Stage: Morel 6.2 Comp Set
Subs: 2 IDMAX 12 D4s
...and a hell of a lot of MDF, Fiberglass, RAAMAT, and Expanding Foam
To come: 200 MHz Mobo, 30 Gig HDD, Sproggy MK 2.6, LCD?
Correct me if I'm wrong, but you should be able to hook a 12V fan to a 5V line. It'll just run slower than normal.
But I agree with the consensus of hooking it directly to the car's 12v line.
All my fans are connected to unregulated +12V....Seems to work fine for me since they have been running for 3 years.![]()
what about a tank for your fan when you crank?
[SIZE=1]'91 Nissan Stanza
[XXXXXXXXXXXXXXXXXXXX] XX% Completed -
Car Totaled and i bought a 20G mp3 player
http://machs-fuel.tk
a DIY video projector page
just get an annoying 12v fan that would work ok, even if it ran slower. hook it to the 5 then
My car's electrical system in working properly, with a good battery (Optima Red Top) and a good working alternator. I don't need kludges like tank circuits.Originally posted by Machs_FueL
But seriously, a few seconds of cranking isn't going to hurt a fan at all.
