Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Ram Drive
    Jun 2002
    Barry, South Wales, UK
    Ram Drive
    Would it be possible to set up a ram drive & install the OS on it for superfast boot up? & then have a hdd for mp3's
    Reaper - reaper_uk_99@yahoo.co.uk
    I'm in shape...... round is a shape!
    [-(10%)---------]
    Volvo 740se, ???, awe64 Gold, ati rage with tv-out & a HUGE 192mb hdd (For testing!) (had to give the PII 350 to my mum :( )
    Mar 2002
    it's possible, but your ram drive would be erased every time the computer is shut down. I suppose you could have a key in the autoexec.bat or something that would transfer system files from a HDD to a Ramdrive during boot up, which would increase boot speed.
    Ram drives usually aren't meant for permanent storage.
    birrman54
    Jun 2002
    oh well was worth a thought
    [-(10%)---------]
    May 2002
    Roseau, MN
    No it would work. They did this on the Screen Savers a few months ago. They installed Half Life on a portion of the system's RAM. Damn! It literally loaded in a second.
    They had to get some program to do this, obviously, but it's possible. The only real problem is that you may need more RAM to do this. And the more RAM you have, the longer it takes Windows.
    HU: Clarion 9575RZ
    EQ: Clarion 90EQ
    Amps: Dei 1100d and DEI 400
    Front Stage: Morel 6.2 Comp Set
    Subs: 2 IDMAX 12 D4s
    ...and a hell of a lot of MDF, Fiberglass, RAAMAT, and Expanding Foam
    To come: 200 MHz Mobo, 30 Gig HDD, Sproggy MK 2.6, LCD?
    May 2002
    Sef'Kylar
    The problem isn't so much getting the stuff in the ram, the problem is making it stay there.
    RAM is volitile.. when you power down the data is lost.
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Feb 2002
    yes that would work for loading programs, but you can't boot windows from a ram drive because as soon as you turned off your computer it would erase windows from ram and you would have to copy it back to ram before booting again (which would defeat the purpose). They have some ide ram drives that require power at all times to keep the data on them, but they cost WAY too much money.
    sv24, 733mhz celeron, 80gig hd, 5.6" MA Audio tft, x10 remote, RF Keyboard.
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    What about compact flash ?
    I've heard that compact flash could be connected as IDE device -
    32 Megs would be ok for small OS like MSdos or some little linux ?
    and possibly 128 or 256 for win98lite ? I don't know the speed of Compact flash but I think this could be a solution ?
    Felix
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    May 2002
    Sef'Kylar
    My USB smartmedia setup is pretty damn fast..
    it would be a feasible solution I think if it's faster. It certainly requires less power.
    A rom board would be nice
    aka Kumaneko
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    the downfall of smart media is its lifespan tho. i don't remember the exact numbers, but its got a limit to how many write/erase cycles it can perform before it wears out. so dos, or linux in a read only mode could both work well.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Aug 2003
    Quote Originally Posted by Birrman54
    birrman54
    How about storing a hd image on a cf card and then imaging it on the ram drive? Here something i want to try. Booting to dos from the cf, then run a .bat file to create the ram disk, the loading the stored image into the ramdrive.
