Results 1 to 5 of 5
Thread: usb hub with 12v psu
    May 2000
    Ft Gordon, GA
    Talking usb hub with 12v psu
    i finally found a usb hub that doesn't require an ac power hookup. thought i'd share: http://www.tcwo.com/cgi-bin/webc.cgi...gi2Ty0GcHbI3nP
    "if everything is under control, you're not going fast enough!"
    Mar 2001
    Perth, Australia
    Post
    you need one that is a controller two, so you dont need to plug it into a usb port
    May 2000
    Ft Gordon, GA
    Post
    i really dont. i have 2 usb ports built in and could use a few more. ive heard others say the same....
    Mar 2001
    Perth, Australia
    Post
    okay you dont need to have one that doesnt run off usb, but what difference does it matter if it gets it power from 12volt or the actual usb port?
    but one that would allow other ppl's old pentium and amdk6-2and3 with out usb ports would be cool if thats possible.
    Jul 1999
    Greensboro NC
    Post
    PaulyZ: You can go out and buy a USB card for your computer...as long as you have an open PCI slot you can add 2-4 USB ports to any PC with the proper software drivers.
    Catlas
