Results 1 to 6 of 6
Thread: problem, can't get dvd burner hooked up?
    Oct 2006
    I have the VIA MII10000 motherboard with 512 ram and the M2-ATX PSU enclosed in the VoomPC case. If your not familiar with that case it doesn't have an area for a slim dvd/cd drive so I need to connect one via USB...
    anyways, i have the slim dvd drive in an external enclosure (http://cgi.ebay.com/ws/eBayISAPI.dll...2830&rd=1&rd=1)
    which I have seen other members try and had success so i gave it a try.
    When i plug it into the USB port it find it ok but only for about 30 seconds then the drive dissappears? I searched and saw some people mentioning it might not be getting enough power so I tried it also using power from the PS2 port but that didn't work either...
    Any suggestions?
    Elsewhere
    How would you power it from the PS2 port?
    It might be more useful to provide teh 5v that the drive requires either from the power supply or some other 5v source.
    How about the Wiki?
    Low Bitrate com2soft's Avatar
    Sep 2006
    i had seem only ext dvd that can run solely on USB power. but it is a burner it may require another 12V or so. check its rear end to see.
    Oct 2006
    Quote Originally Posted by DarquePervert View Post
    it came with a cable, firewire on one end to connect to the drive...usb and a ps2 on the other end. once the ps2 is plugged in to lets say the mouse port it provides the drive with power.
    Oct 2006
    Quote Originally Posted by com2soft View Post
    thanks i will take a look at it when i get home.
    Elsewhere
    It's 5v, if you get power from USB. USB doesn't supply 12v at all.
    Another option is to hack into a molex and draw 5v power from there.
    This is a topic that has been discussed many times on these forums. Have a search and you'll find lots of options.
    How about the Wiki?
  1. A DVD burner for 122USD good find?
    By bimmerpc in forum General Hardware Discussion
    Last Post: 06-30-2006, 09:01 AM
  2. FS morex 3688 case plus pioneer dvd burner
    By shoisfast in forum Classified Archive
    Last Post: 01-19-2006, 09:14 AM
  3. FS: External Slim Line DVD burner for sale!
    By EsKALad in forum Classified Archive
    Last Post: 02-06-2005, 07:48 PM
  4. Bug Reports
    By frodobaggins in forum FrodoPlayer
    Last Post: 10-16-2004, 12:25 AM
  5. DVD problem in MediaEngine
    By SteveC in forum Media Engine
    Last Post: 07-27-2004, 05:08 PM
