Results 1 to 4 of 4
Thread: Rear View Camera Selection - Night
    Apr 2002
    I am looking for a good quality rear view camera as I am mounting a larger spare tire on a tire swing soon, obstructing my view. This isn't just for reversing, it'll have to be decent enough to use for rear view, and during the night. I have heard that often cameras have a tough time being sensitive at night without becoming flooded with light by headlights.
    The best two options I have identified are these:
    MP3Car $169
    http://store.mp3car.com/ProductDetai...Show=TechSpecs
    http://mywebpages.comcast.net/yanlab...ew_camera.html
    Color CCD Flush Mount Night Vision Infrared Wide View Angle Vehicle Camera. This new model can now be used as a rear-view or front view camera. Uses standard vehicle power supply of 12V DC unregulated (some vehicles have a very high momentary voltage at the vehicle starting time and the overload might cause damage to the camera. If that is the case for your vehicle, you will need to install a fuse, voltage regulator, etc. to protect the camera). Water-proof without extra housing: for part (camera glass lens) exposed to outside ONLY and for normal usage ONLY. Camera body and cables are not designed to be exposed to outside and must be properly sealed against moisture. Incorrect installation and abnormal usage MAY result in loosing water-proof feature. Wide View Angle 110 degree - If you just buy a cheap 40 degree rear view camera, why bother? You can see more with your own eyes (through standard vehicle mirrors) than the camera can see! Without a wide view angle lens, it is not a vehicle rear view camera! Standard RCA video output
    Image Sensor 1/3" SHARP CCD Sensor
    Effective Pixels 519(H) x 492(V)
    Sensing Area 3.6mm x 2.7mm
    Video Out Signal 1.0 Vp-p 75 ohm
    Auto Electronic Shutter 1/60 - 1/100,000 second
    Dimensions 30 mm x 63 mm
    Standard RCA Video (Yellow) & DC (Red) Jack
    White Balance Auto
    Operating Temperature 14°F - 122°F (-10°C - 50°C) / RH 95% Max
    Current Consumption Max 200mA
    Horizontal Resolution 420 TV Lines
    Minimum Illumination LUX (w/IR LEDs on) / F:2.0
    Sync System Internal
    Power Supply DC 12V
    S/N Ratio Better than 48dB
    Weight Approx 50 g
    Built-in Lens f=2.8mm / F=2.0
    TV System NTSC
    Lens Angle Wide View Angle 110° Min
    Review by RoyN posted here:
    StarTek CN-58-WH $139 bare + $39 cable
    http://www.startekvideo.com/rear_vision.htm
    link to full pic: http://www.startekvideo.com/CAM%20%20CN-58-WH.JPG
    WEATHERPROOF, COLOR and B&W NIGHT VISION
    High Resolution CCD Image Sensor
    photodiode switches on IR LEDs in low light
    Auto Iris - <0.5 Lux Color, 0 Lux B&W
    IR Illumination 30+ft for Automatic B&W Night Vision
    420 TV Lines
    oper temp: -10° to +50°C
    12VDC Pwr jack (10-15VDC)
    Aluminum case 1.9" dia x 2.4" long, Hood 3.3" long.
    COLOR: BLACK Aluminum case.
    Weatherproof with Mtg Bracket
    100 ft Audio-Video-Power Cable with connectors
    Thoughts:
    The MP3Car doesn't have a waterproof body for mounting in the bumper and I don't know if its night vision LUX rating is as good, nor do I know if it switches to B&W at night.
    The StarTek probably can't be flush mounted, is larger, and is a bit uglier. I don't know if anybody here has one to say anything about its quality.
    Do you know anything more about either of these? Any other good options?
    Apr 2002
    BTW, this will be used with a DWW-700H via the RCA input
    http://www.digitalww.com/DWW-700H.htm
    Newbie flyingwil's Avatar
    Dec 2005
    Mesa, AZ
    Might be a little late to jump in but this camera is pretty sweet:
    http://www.totalvisionproducts.com/
    Nov 2005
    Where?
  1. [REVIEW] In-Bumper Rear-view camera
    By RoyN in forum General Hardware Discussion
    Last Post: 12-30-2006, 03:42 PM
  2. LED display in Rear view mirror
    By Dan Patzelt in forum Fabrication
    Last Post: 08-05-2005, 10:43 AM
  3. FS: 5" Rear View Mirror monitor!
    By DLe in forum Classified Archive
    Last Post: 09-30-2004, 09:57 PM
  4. Is non-IR rearview camera visible at night with reverse lights on?
    By hd54321 in forum General Hardware Discussion
    Last Post: 07-23-2004, 04:21 PM
  5. Cheap camera with night vision
    By mxxxxxm in forum General Hardware Discussion
    Last Post: 06-04-2003, 12:55 AM
