View Poll Results: Would you be interested in a Kontron 986LCD Mini ITX board w/ 800x480 support?
Voters
27. You may not vote on this poll
  • Yes!
    23 85.19%
  • No.
    4 14.81%
Page 2 of 11 FirstFirst 1234567891011 LastLast
Results 11 to 20 of 106
Thread: Kontron 986LCD-M/mITX, and 800x480 LVDS.
  1. #11
    Feb 2004
    Excellent news!
    They're going to customize the video BIOS free of charge.
    All I have to do is send them the data sheet for the 9.0" 800x480 LVDS LCD panel that I'm getting.
    Once that's done, I'll send the BIOS image to whoever wants it - just PM me if you need it.
  2. #12
    Nov 2006
    I'm glad you're on top of this. I'm planning a very similar setup. PM sent.
  3. #13
    Feb 2004
    I ordered my 986LCD yesterday, by calling Kontron directly.
    Total was $487:
    986LCD was $396
    Accessory kit was $15 - all the cables and such.
    Low profile (1U) heatsink / fan was $76.
    I have a nice 24" widescreen LCD at home, which I should be able to use to test 800x480 on Analog VGA..
    Of course, at that resolution, each pixel will be about 5mm in size..
  4. #14
    FLAC SFiorito's Avatar
    May 2004
    so this video BIOS will support 800x480 on all video outputs (VGA, DVI, LVDS)? What LVDS panel you using?
  5. #15
    Feb 2004
    Quote Originally Posted by SFiorito View Post
    Well, the first thing I will test will be the analog VGA, to see if it supports 800x480 with the standard BIOS.
    If it does, then that helps 90% of the people here.
    I can test DVI as well, but I'll need to get a SDVO PCI Express add-on card to do so.
    The LVDS LCD panel will be a 9.0" Wide panel, 800x480 at 24-bit color (16M), single channel LVDS.
    See my thread in LCD section for details..
    Since it's single-channel, according to Kontron I should be able to connect two LCD panels to the onboard LVDS.
  6. #16
    Feb 2004
    I updated my order from Kontron yesterday to include the DVI add-on card.. it was $27, and goes in the PCI-E slot.
    Also, the accessory kit is $76, not the fan.. the fan is $15.
    I also ordered the black Opus Itx case from Mp3car.
    The opus 120W supply is enough for the board under heavy load, according to the 986LCD's manual power draw reports..
  7. #17
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Interestingly enough, I bought an engineering sample 986LCD board a couple months back (haven't put it together yet into a carPC) and it has both a PCI-X slot, a regular PCI slot, and a mini-PCI slot. Looking at Kontrons website, the actual ones for sale don't make any mention of the regular PCI slot.
    Anyone know what happened?
    Dave
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
  8. #18
    Feb 2004
    Quote Originally Posted by Caelric View Post
    Dave
    Wow, I'm surprised.. yours didn't come with a PCI slot?
    I'm pretty sure that the manual, dated in November, listed a PCI slot, with support for a 2-slot riser.
    Let me check with my Kontron sales engineer.. my board ships dec 15th, so it had better have a Pci slot...
  9. #19
    Sep 2005
    Bellevue, NE
    No, mine does come with a PCI slot, as well as a PCI-X slot, and a mini-PCI. But if you look at kontrons website, it doesn't mention the PCI slot
    Core Duo CarPC
    CarDomain page
  10. #20
    Feb 2004
    At first glance, they don't mention it.. but it's there in the spec sheets.. the PcI slot is why I bought it..
    The slot underneath is Pci express mini, not mini pci.. slight difference.
  1. Replies: 19
    Last Post: 04-21-2010, 05:35 AM
  2. Has anyone EVER gotten a Lilliput to detect 800x480?
    By larry_llama in forum LCD/Display
    Last Post: 12-03-2006, 03:05 AM
  3. 800x480 on the SP13000 with Powerstrip
    By theminor in forum LCD/Display
    Last Post: 10-16-2006, 11:32 PM
