Results 1 to 10 of 10
Thread: mounting a slim load dvd drive upside down
    Nov 2006
    Do you think mounting a slim load drive upside down will cause any functionality problems? The reason I ask is because the drive advertised here has the loading slot closer to the top of the drive, which may be covered by part of the dash in my coming up install. I know that if I mount it upside down the slot will be in just the right spot.
    Thanks in advance,
    -Daniel
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    Quote Originally Posted by daniel_gabriel View Post
    Thanks in advance,
    -Daniel
    i have mine verticle. No problems related to the positioning. Now i have had problems cause i fed it 12v instead of 5v lol
    Nov 2006
    Yeah, I would assume that vertical mounting wouldn't create problems. But I'm not sure about how the whole loading mechanism works, so possibly upside-down mounting would be problematic. Has anyone tried this before?
    Thanks,
    -Daniel
    It ain't easy being a green moderator meddler's Avatar
    Aug 2002
    Steps out the front of Henson's workshop or Sydney
    I tried to mount my imac slot load dvd drive upsidedown. It didn't work. It wouldn't take the discs properly and if it did, they wouldn't play. The best thing you could do is to try it before you mount it in the car.
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    I'm going to guess probably not, because it won't be able to center the disc properly and probably won't be able to hold the disc in place while it tries to spin it.
    Nov 2006
    That's what I thinking too. Oh well, I guess I'll have to make it fit right side up.
    Thanks.
    Constant Bitrate ramez75's Avatar
    Dec 2006
    Nazareth PA
    A recommendation why dont you try it, just hook it externally to a desktop or laptop and try to play a dvd and/or CD when it is in the upside position.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    I just tried it with my panny DVD/CDRW and it worked fine.
    Just remember to put the Disc's in upside down! (puzzled me for a minute...)
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Sep 2006
    if the center spin motor of the drive actually holds the cd, (like you have to push to snap it in) then you should be fine, but if its a slot load then I dont think it will work.
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by i700plus View Post
    Sorry, I should have specified this earlier.
    Mine is a slot load drive. It worked fine. I didn't try a DVD, nor did I try burning, but it worked fine and I was able to copy data of a CD.
  1. Slim dvd drive problems. JAE 50pin to IDE at fault?
    By 2k1Toaster in forum General Hardware Discussion
    Last Post: 08-16-2007, 05:06 PM
  2. Slim slot load DVD ROM drive
    By jbors in forum Classified Archive
    Last Post: 03-17-2005, 08:31 AM
  3. Slim Slot Load DVD Drive - $110 Shipped!!
    By dapilot in forum Classified Archive
    Last Post: 06-23-2004, 03:05 PM
  4. slot loading slim dvd drive? any chance?
    By spectrrr in forum General Hardware Discussion
    Last Post: 03-05-2004, 04:55 PM
  5. Pioneer Slot Load DVD Drive Shock Resistant?
    By Bloomk in forum General Hardware Discussion
    Last Post: 01-15-2000, 05:46 AM
