Results 1 to 7 of 7
Thread: Vibration/shock pc problem - not the HDD
    Newbie hondapc's Avatar
    Apr 2006
    Los Angeles
    Question Vibration/shock pc problem - not the HDD
    My PC is mounted in my trunk behind the seats. The PC is freezing when I drive over a bump or when the sound is really loud. First I’ve thought it must me the hdd, but it’s not. (I’ve tested it with the hdd out, same result.)
    I’ve searched the forum about this problem but everything I found about shock/vibration is hdd related.
    Why is this happening? Nobody else seems to have this problem. Cpu ? Memory ? Should I mount the pc on rubber washers?
    Mar 2006
    Colorado, but Canadian!
    The first day I installed my PC, I had this problem too. I couldn't figure it out, so I reinstalled XP to start from scratch to eliminate the possibility of a software problem. It went away. No idea what was "fixed", it just went away.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC SnyperBob's Avatar
    Nov 2001
    Illinois
    It is possible that it's memory or something else plugged into the mobo. I'm not sure about your particular setup, but check the memory first. I assume your CPU has brackets to hold it and/or a heatsink and fan in place.
    i know they make things called card keepers which help secure parts in place in a pc. I'm not sure if they make them for memory, but I know they make them for PCI/agp devices (sound card, graphics card, etc)
    www.mobile-effects.com
    Free file hosting, picture gallery hosting for installs, PM me.
    Internet's first Front End Skin browser, featured installs, downloads, links, informative articles - all free to registered users.
    Apr 2006
    Los Angeles
    Ok, so I’ve took the computer apart, I’ve found out the problem is the processor. If I tap the CPU cooler with a screwdriver the pc is freezing. The memory is ok I can tap it, twisted it, and it’s still working.
    Now why is the CPU so sensitive & what can I do to fix the problem?
    It is a Intel Celeron D 2.60GHz at 533MHz on a mini barebone dtk pc. The brakets are in place. Nothing else is plugged in the mobo.
    Apr 2006
    Los Angeles
    I guess I'll have to buy a new computer. I couldn't fix it. Any sugestions for a pc? I'm thinking to buy a SFF DELL on ebay... i don't want to spend more than 200$ on another pc. Maybe a Dell OptiPlex SX260.
    Dec 2004
    Athens Greece
    Have you try electrical contact spray?
    Have you deinstall and reinstall CPU?
    I don't beleive it is CPU problem , but how CPU connects to the board.
    Check all contacts one by one, if they fit exactly every hole of the board.
    Dec 2004
    Athens Greece
    Check if all "legs" of the CPU are symetric and not bended too.
  1. Weird problem with Nokia PC Suite and Bluetooth
    By Rafster in forum Wireless Communications
    Last Post: 06-12-2005, 04:41 AM
  2. Pocket PC With USB HDD and PCMCIA Sound Card?
    By greenglo in forum General Hardware Discussion
    Last Post: 02-23-2005, 05:26 PM
  3. Full size PC if space is not a problem?
    By popuptoaster in forum Newbie
    Last Post: 11-26-2004, 07:42 PM
  4. pocket pc lcd view angle problem
    By babas151 in forum LCD/Display
    Last Post: 11-01-2003, 12:05 AM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
