Results 1 to 5 of 5
Thread: Case usb connector causes M/B not to power on
    Maximum Bitrate nasa's Avatar
    Aug 2006
    PA
    Hi,
    Figured you hardware experts would be the correct people to help me with this issue.
    I have this case:
    http://www.opussolutions.com/index.php?p=product&id=27
    and this M/B
    http://store.mp3car.com/ProductDetai...Code=MTB%2D014
    both bought from mp3car.com.
    The problem:
    when I connect the usb header from the case to the M/B the sytem doesn't power on... Even my usb mouse (connected via ps/2) doesn't light up.
    Troubleshooting:
    1. When system (based on the above equipment) failed to power on, I removed the header and all went well.
    2. I plugged in a usb header into the M/B listd above (one connected to a slot rail) and all went well.
    3. I plugged the case header into a different M/B and all went wel.
    Anyone have any idea what would cause this? The troubleshooting steps would make it seem that both the header and the M/B work, but combined they don't. I checked the BIOS to ensure nothing was trying to boot of the USB ports. I verifed this by connecting a USB thumbdrive into one of the M/B USB ports and it was ignored, as expected.
    Nasa
    Aug 2006
    PA
    Back again,
    failed to note that this is powered via an ATX power supply, so I doubt that power is the issue.
    Nasa
    FLAC evandude's Avatar
    Mar 2005
    Maine
    The case connectors may have the ground wire connected to the chassis. If you hooked it up wrong, it would mean some other wire would get shorted to the chassis, so I would make sure it's plugged in the right way if I were you. Also, the case connectors could just be screwed up and have a short or something. Spend a few minutes with a multimeter and check for short circuits between all the pins on the header connector, and between all those pins and the case. Since the thing is nothing more than some wires going to a couple connectors, there's not really much else that COULD go wrong.
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Aug 2006
    PA
    Thanks for the reply evandude,
    I looked closer at both the cable/pinouts on both the usb connectors -- they are different. The one that works looks like this:
    x x x x o
    x x x x x
    R W G B
    R W G B
    The questionable one:
    x x x x o
    x x x x x
    R W G B B
    B G W R B
    x = female sot
    o = no slot
    R = red
    W = white
    G = green
    B = Black
    Motherboad pinout specs (from M/B manual for new motherboard)
    USB5-6
    Pin Signal Pin Signal
    1 USBVCC 2 USBVCC
    3 USBD_T5- 4 USBD_T6-
    5 USBD_T5+ 6 USBD_T6+
    7 GND 8 GND
    9 Key 10 GND
    Motherboad pinout specs for test M/B
    1 VCC 2 VCC
    3 Data- 4 Data-
    5 Data+ 6 Data+
    7 GND 8 GND
    9 10 OC
    So since both M/B's are looking for the same thing.... Why does it work on one, but not the other. and is the one that is in question wired wrong?
    Nasa
    Aug 2006
    PA
    Ok,
    I fixed the problem by rewiring the usb connector -- it wasn't wired correctly. It works as advertised now.
    Nasa
  1. power requirements for 2 USB hubs (urgent)
    By ramy_zohair in forum General Hardware Discussion
    Last Post: 11-11-2005, 08:27 AM
  2. Xenarc - USB Power cable?
    By Coeus in forum Power Supplies
    Last Post: 01-13-2005, 09:07 PM
  3. USB Power problem please help
    By Uconnputer in forum Power Supplies
    Last Post: 12-07-2004, 12:29 AM
  4. usb accessories, how much power do i need?
    By chris in nh in forum Newbie
    Last Post: 06-01-2004, 09:17 PM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
