Results 1 to 8 of 8
Thread: adding another sound card??
    moahdib's Avatar
    Jul 2000
    Post adding another sound card??
    If I have 2 sound cards installed, is there a way to make winamp sound go through one sound card and like windows media player sound to come out of another card? I am thinking of adding another LCD for rear passangers and would like to have them be able to watch a movie through headphones while I can listen to music.
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    Jun 2000
    Salt Lake City, UT, USA
    Post
    Can you really get two sound cards working at the same time? I have never tried that.
    Another thing you could do with that is use 2 2-channel sound cards to make 4 chanel sound in the car.
    1983 BMW 733i
    Cyrix 166 32MB with MPXPLAY And no display. Player sits on the back seat with a keypad in front. Someday I'll mount this thing for good...
    Gathering parts for carplayer v2.0!
    mpt
    mpt is offline
    Jun 2000
    Setubal, Portugal - Europe
    Post
    I know you can select a output sound card on winamp. Just go to Options > output Plugins, select Nullsoft Directsound or Nullsoft waveout and configure your output device (should appear more than one output device).
    Perhaps itīs better to leave the primary sound card to Media Player and leave the second one to Winamp. Never tried it but in theory could work.
    Cheers
    mpt
    moahdib's Avatar
    Jul 2000
    Post
    Perhaps it's worth a try. I know I posted twice about the same subject but for some reason I couldn't see my post last night so i put a new post hehe
    My TL CarPC ver2
    Apr 2002
    Chelmsford, MA
    A couple questions:
    Anyone tried this yet? What is involved in getting it to work?
    Would it be possible to have a second screen with some other input (touch screen, number pad, etc.) to effectively have two separate outputs sharing one carputer? My thinking is that the people in the back seat could control their screen with separate controls from the front screen, all while using one cpu/motherboard.
    Let me know if this is possible.
    thanks
    Scott
    Apr 2001
    Here, There, Everywhere
    from my experience on my home PC 2 sound cards are fine..... I have a Vibra 128 sound card and a USB sound card with digital optical output for my minidisc player. Both work together at the same time fine..... like a few said earlier, you can use winamp to pick the output sound device.....
    if your gonna try 2 PCI sound cards together, I guess you might possibly have some problems with certain sound cards together, a bit like problems that sometimes exist with trying to run 2 video cards for dual monitor support....
    with windows media player I dont think you can pick a sound source, but you can pick the 'default' sound card for windows to use.... so set that to the one for windows media player and use the other one for winamp.....
    should work fine.. maybe try for a PCI/USB sound device combo?
    Project - GAME OVER :(
    Oct 2001
    TASMANIA Australia
    I Used to do this with an old vibra 16 and an ensoniq pci 128, works fine, you can set in the multimedia controll pannel which card is the primary one that windows uses and you can set in winamp which one you want it to use.
    As long as both cards use different address settings (irq, dma etc) then you shouldnt have any problems,
    95 mitsubishi Magna
    MK2 <+++++++-->80% (On Hold for MK3)
    MK3 <----------->5% (Obtaining Parts)
    pentium II 233, sproggy 2.7 ATX ps, 10 in Active Matrix VGA LCD, Custom keyboard, 802.11b Networking , Creative Remote, Relay Control
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    Virtual Turntables....
    More or less a bit off-topic but,
    I have done this once with 2 identical soundcards (Creative 128 pci) and using the software virtual-turntables...
    This would output to a mixer where I control the 2 seperate inputs as if it were 2 turntables...
    Worked like a charm, so I think this must be possible with other programs too..
    Greetz
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
