Sorry but its not likely that someone is going to tell you what board to get.
But with the few requirements that you have specified, just about any board will work.
Just about every board I have seen, supports multiple hard-drives with IDE, and any SATA board I have seen, has more than one SATA port on it.
Also For the past several years, every board I have seen or purchased has had at least 2 USB ports.
It looks like you are thinking along the lines of more power. Just remember with more power, you get more heat and power consumption. There wont be a constant 120v running to this thing like from a house, and just plugging in an 500w power supply. Power supplies for car pc's dont seem very cheap, and the wattage that I have seen is not up there with standard desktop applications.
If your just wanting to build a juke box, then I dont think you need to go as strong as a 2duo
LinkBack URL
About LinkBacks
