Results 1 to 3 of 3
Thread: Via Cpu ???
    Dec 2006
    Question Via Cpu ???
    I am getting very confussed with the VIA c7 range... offering same clock speed and different power usage.
    Will a 7.5W 1.5ghz VIA c7 perform the same as a 25W 1.5ghz VIA C7?
    How do the via C7 compare with the Geode range,
    I am designing a system to act as a record on movement security device for when I am not with the car. As the car will be off how long can a car system run on the cars battery (it has a typical battery will have to check exact Ah)?
    Are there any recomendations for hardware to extend run time without compermising too much on performance ?
    will I be better off with usb webcams or a PCI CCTV board from a power consumption point of view?
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    Not sure but power difference is probably down to different on board stuff.
    For power consumption take total watts divide buy 12 will give you amps, divide Ah of battery by amps and that will tell you how long it will run for. Take a bit off as you don't want to discharge the battery too much.
    Power wise the usb will be better but as their video performance is rubbish and this is for security then use the proper cctv boards.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Dec 2006
    I understand the physics of what your saying but can anyone with a VIA c7 system let me know how long it will run on their battery (engine off) untill the current converter trips out?
    if you can put your spec and battery Ah that would be great help
  1. Motherboard or CPU....which one's dead?!
    By Munkeyd00d in forum General Hardware Discussion
    Last Post: 04-05-2006, 01:02 AM
  2. M2-ATX Question - 24 Pin Motherboard w/ 4 PIN CPU
    By tbird2340 in forum Power Supplies
    Last Post: 02-15-2006, 02:57 PM
  3. COMMELL LV-667T w/ VIA C3 1.00GHz CPU INFO please
    By KF4ODQ in forum General Hardware Discussion
    Last Post: 08-10-2005, 04:10 PM
  4. Mobo, CPU and power rail
    By MatrixPC in forum General Hardware Discussion
    Last Post: 11-15-2004, 10:19 AM
  5. CPU Heat question: Which one would generate less heat?
    By kiztope in forum General Hardware Discussion
    Last Post: 02-12-2004, 03:14 AM
