Results 1 to 7 of 7
Thread: hard drive failure in cold temps
    Feb 2002
    indiana
    Post hard drive failure in cold temps
    My maxtor 20gb hard drive wont spin up when the outside temp is less than 40 degrees F. Does anyone else have this problem? I checked out the specs on most of the big name drives and most have operating temps listed at 5 to 55 degrees C, which I think 5 degrees C is around 40 degrees F. Are there any hard drives that can operate at lower temps?
    Oct 2001
    NYC
    Post
    thats ridiculous...mine both work fine at below 0C
    Feb 2002
    indiana
    Post
    Maybe laptop hard drives work better in cold temps. I have a Neo 35 mp3 player that only uses a regular drive for a desk top computer. I also have tried a western digital hard drive and it did the same thing. Right now I have a heater that plugs into the cigerette lighter to warm it up. After it warms up it works fine.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Post
    i dont know if its my drives, but i have horible stability/booting problems when its cold out (18F this morning in chicago). ive got an old 2gb segate medalist and a 60gb wd.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Retired Admin Aaron Cake's Avatar
    Jan 2000
    London, Ontario, Canada
    Cool
    Hmmm...I did not have any cold related problems with either desktop drives or my current laptop drive. Are you sure it's not a power supply issue?
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    Post
    I'm not surprised - After all, read the manufacturer's operating temp specs. Usualy it's a moderate temperature range around 50deg-110deg F (Just looked it up on WD's site: Their drives operate from 41-131 deg F)
    Western Digital's specs on a 20gb drive
    Anything higher or lower will result in safeguard shutdown. Interestingly enough though, it can take 65G of shock for 2ms while operating... that's pretty resiliant!
    Feb 2001
    Somerville, MA
    Post
    It seems like something is strange with all those operating temps. I suspect they only test from 5 to 55 C, cause almost every HD out there claims that is their operating temp. Probably many of them work at higher and or lower temps.
    Twostep
