Results 1 to 8 of 8
Thread: Power button (MKIV VW specific question)
    Jan 2006
    Lexington, KY
    I'm thinking about getting extra switch (see pic below) to be used a "master" power button for the PC and the monitor. I don't know much about vehicle electronics so I need to know if someone on here has done that or think it's fairly easy to implement, possibly get some insight.
    Reasoning behind this is simply OEM look and I make short trips daily and I don't want the PC to start every time I start the engine.
    Here's the pic of the switches I'm talking about:
    Any dubbers already done that? RedGTiVR6?
    _
    Mar 2004
    Little Elm, Texas
    nope - haven't made the change. I added the switches inside the glove box because I didn't want the computer to turn on when and if we had to valet the car or if I had to take it in to be worked on at the dealership.
    I have a pair of switches for the PC (one as a reset and another to completely cut power), and another pair for the Alarm as well.
    Jan Bennett
    Jan 2006
    Lexington, KY
    The switch (in OFF position) could instruct shutdown controlled to shut the PC down?
    _
    Mar 2004
    Little Elm, Texas
    If I put the on/off switch to off, the computer will not boot up with the ignition. It basically opens the circuit.
    If I need to reset the computer, I just hit the reset button.
    I'm running the M1, so it handles the start-up shut-down features as needed. The switches are to bypass all of that.
    Jan Bennett
    Jan 2006
    Lexington, KY
    If the switch was in the ON position and the PC was on, then I would put the switch to OFF position - would that make the shutdown controller shut down the PC? Or would you still have to manually turn the PC on? And vice versa.
    Newbie Aquaman's Avatar
    Oct 2006
    Frisco, TX
    It depends on how your circuit is configured. If the switch controls the master power for the PC, if you open it (sw in off), the power to the PC will be cut, and it will not have enough time to shutdown (unless it is a laptop with a working battery, of course). If the switch controls the ingnition pin in your shutdown controller (i.e. you wire it instead of the ignition switch of the car), if you open it will have the same effect as putting your ignition switch in off, normally instructing your PC to shutdown.
    Jan 2006
    Lexington, KY
    That's all I needed to know. Thanks RedGTiVR6 and Aquaman
    Jan 2006
    Lexington, KY
    I purposely waited a year just to bring this thread back
    Never got around making the switch work until now.
    Didn't look in to how these stock switches work until now and what I've found is that it needs to be debounced.
    Now, does anyone know if Carnetix CNX-P2140 is capable of providing debouncing before I go and start hacking the switch?
    Has anyone on here with MKIV done this? And how did you do it?
    Thanks.
  1. Replies: 25
    Last Post: 04-27-2008, 05:40 PM
  2. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  3. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  4. Shuttle power button?
    By mazda3uzr in forum Power Supplies
    Last Post: 02-06-2005, 05:36 PM
  5. ITPS reprogramming ?
    By naruto in forum Power Supplies
    Last Post: 11-26-2004, 02:19 PM
