Results 1 to 10 of 14
Thread: Speaker Config
    Sep 2006
    Cornwall, England
    Speaker Config
    Right, here's the deal.
    I want to use a Via Epia MII 12000 motheroard in my car computer along with 3 amps for the speakers. There will be one for the front speakers, one for the rear and one for the sub. I havn't bought this gear yet, as I am still writing my front-end, but anyway, my question is...
    How can I configure the speakers ports on the motherboard so I can have separate sliders for the Front, Raer, and Sub. I have been trying with my desktop computer, but if I configure it for 5.1, Line-In and Mic-in work the rears and centre/sub, which is fine, but Winamp doesn't output anything to these channels, just the front! That is the same with any stereo playback software I think.
    As mentioned, I don't want 5.1 channel sound, I just want the same sound to come from all the channels so I can fade them up and down when required.
    Has anyone used this method it there car PC projects?
    _
    Mar 2004
    Little Elm, Texas
    most people use something like the Alpine 701 processor to do what you're wanting to do.
    The issue with using the on board audio ports is that the voltage is too low out of the board. This means that your noise floor will be very low, meaning you will be more likely to pick up noise in your audio signal.
    Using an outboard processor or a better sound card (internal or external) usually means you will have higher output voltages which means better quality audio.
    Jan Bennett
    Sep 2006
    Cornwall, England
    Apart from the Alpine, is there anything else I can use. I didn't really want to have a head unit, just my car PC and my amps.
    _
    Mar 2004
    Little Elm, Texas
    The Alpine 701 is not a head unit, it's a processor. The face plate it only about an inch thick. There's no place to put CDs in.
    Other than the Alpine, you can go out of the onboard sound to an EQ of some kind. There's many 1/2 din EQs avaliable out there that will take lower voltage in and bump it to a higher voltage out.
    Jan Bennett
    Sep 2006
    Cornwall, England
    Smile
    Quote Originally Posted by RedGTiVR6 View Post
    Thanks for the reply.
    Is this really the only way of doing it? It seems pretty expensive. I'm not saying I want to have bad quality, as I have spent over 6000 on my home stereo system, but is the quality from the onboard sound that bad? The carPC will mounted only inches from the amplifiers, so I thought that the noise pick-up would be fairly small.
    As the car PC is going to be mounted so close, there is more chance of picking up noise running the cables from the PC to the dashboard (where the EQ would be)?
    Quality is a major concern with me, so any help is greatfuly recieved.
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    If you have $6000 invested in home equipment I think you will be sadly disappointed by onboard sound unless you ahve a board with the newer HD codecs. You might want to go with a good PCI soundcard or USB/external upgraded soundcard. You will notice a difference. With an upgraded soundcard you should be able to get the control you are asking for. All creative labs 5.1 products and up can do it, as well as turtle beach roadie (look in the MP3car store).
    It's not really the noise that is going to cause you a problem, but I fear it will be the inferior quality components used for onboard versus upgraded.
    Also, you can check out the review and car audio subforums for more info.
    ALso of good note is the FAQ subforum if you really want to use onboard sound.
    Maybe this will help?
    FAQ: How Do I Get 5.1 Audio From My M10000 Onboard Audio?
    Nov 2006
    Have you thought about a seperate controller/line driver?
    This 1/2 DIN unit has 2 channel in, 4+sub out, its own fader/sub level control, 4 ch eq, and up to 13v pre-out to your amps.
    http://www.mobileaudiocontrol.com/pr...2&l1=17612&l2=
    $230
    http://www.woofersetc.com/index.cfm?...roduct_id=1272
    Sep 2006
    Cornwall, England
    Quote Originally Posted by durwood View Post
    So, if I use a good Soundblaster PCI card and run that into my amps, that should give me good quality sound? I have also read on other posts that the Soundblaster software give you a lot of control over the sound that the card produces (ie. equalizers etc.)
    Also, does anyone know if it is possible to play a stereo signal and set-up a soundblaster 5.1 card to have it output the signal equally to the Front, Rear and Sub channels. As all I want to do in my set-up is to be able to fade the signal for the front speakers, rear speakers and sub.
    _
    Mar 2004
    Little Elm, Texas
    The Soundblaster software is not a viable option when compared to other options. It's a feature that's neat to play with, but that's about it. If you want TRUE good quality sound, the software that comes with the cards is NOT what you're after.
    Again, if you go with a SoundBlaster card, or most any aftermarket card, you will have a higher voltage output. This is not necessary, but for most people on this forum, it is. The reason for this is that the higher the noise floor the less likely you are to have induced noise. While correctly running wire and using high quality RCAs can prevent this from happeneing, we all know that the average uses on this forum are not prone to pay attention to these things to the level needed.
    Jan Bennett
    Sep 2006
    Quote Originally Posted by portreathbeach View Post
    The Live series of creative products is not quite as good as the audigy series. I competed in sound qualtiy contests using an Creative Audigy 2 which gave me pretty decent control over the level of each speaker and a time delay(THX control panel) that worked OK, but the 10 Band EQ wasn't good enough, and the time alignment/delay was not as precise as I really needed. The other problem is that their are two different CODECs used on the creative cards and it will give you inconsistent output levels on the front and rear/sub channels. One user on this forum using the LIVE or Audigy SE card reported problems with the sub channel being very "quiet".
    Using CMSS management on the Audigy cards, you can get stereo output to all the channels. Or you can use the KXProject drivers for the creative LIVE/Audigy cards to do more advanced stuff. It works, but it's not precise and it really takes some playing around to get it to work the way you want. I don't miss it for one second.
    The turtle beach Roadie also has a way to "copy" the stereo signal to all the channels. It also has a 10 band EQ on each channel so 5-7 10 band EQs. It is an external USB soundcard.
    I retired my Audigy2 card last year and went for the Alpine PXA-H701 processor. The control and sound qualtiy increased significantly. However, RED and are on our way to retire our PXA-H701's, for a hardware/software solution. If you really want to see some cool stuff check out this thread.
    Software options for Tuning
    For some better soundcards than the Creative products, Check out the Auzentech X-Meridian or the Audiotrak Prodigy 7.1 HiFi. There are reviews on them in the Review subforum. I am using the Prodigy Hifi (~$110) and its very easy to fade the level on each channel and have it run in 8 channel stereo mode.
  1. Speaker Blown???
    By 3onDubs in forum Car Audio
    Last Post: 03-10-2006, 12:55 PM
  2. very strange speaker problem
    By saddlebacks in forum Car Audio
    Last Post: 01-02-2006, 06:36 AM
  3. Self Amplified Center Speaker?
    By c0rrupti0n in forum Car Audio
    Last Post: 11-18-2005, 11:26 PM
  4. center channel speaker underpowered?
    By 00christian00 in forum Car Audio
    Last Post: 07-15-2005, 01:32 PM
  5. car amp with default speakers?
    By 273BeLow in forum Car Audio
    Last Post: 03-30-2005, 12:53 AM
