Well, this would only supplement my existing alarm, not replace it. I am not looking for shock sensors, etc.. for this. The sensors would consist of stuff like switches to tell if the facia was removed, the stereo has been removed, the alarm is triggered, doors opened, key in the ignition, etc.. Fortunately (or maybe not) the
wiring for my car brings nearly ALL the signals I am interested in to an ETAC(?) on just a couple of harnesses. And this is located behind the crash pad and above the fuse box. Should be easy to get to. T-Taps will make it easy to tie into. There is even an 'engine running' discrete at this location!
The two biggest parts of the 'alarm' part will be tieing the 'remote wakeup' to one of the alarms unused channels, and figuring out how to get the controller to arm/disarm the main alarm. Sensing that it is armed or not should be fairly simple (just tie into the indicator LED.)
The unfortunate part is that it wouldn't likely be that easy in another vehicle. But, I will keep that in mind. Might be enough to make the inputs just general purpose 12V discretes or open-collector. Then I could tie whatever I want into them, and change a few lines of code to accomodate.
But, yeah, the wiring itself is the most overwhelming aspect. That is why I am hoping for good planning before install.
