Page 7 of 20 FirstFirst 1234567891011121314151617 ... LastLast
Results 61 to 70 of 197
Thread: Ambitious Video Security System
  1. #61
    Dec 2006
    Coal City (Chicago), Illinois
    Quote Originally Posted by RetroPlayer View Post
    Thanks, I was just reading that part in the manual thanks to you! Definitely planning to enable that feature. There are so many features I want to change, I may have to locate a bitwriter (or figure out how to build one.) I may be able to put a list together and bring it to the installers to do it for me, but where is the fun in that?
    The siren output is going to be one of the triggers. I amy skip the additional switches now that I see some of the features that are built in (but disabled) to this alarm. Definitely a few things are getting rearranged in my plan, now.
    BTW, you mentioned that I could get a two way remote for $60. Is this a seperate module as well as the remote? It doesn't look like from the manual that two-way IS built in. Of course, if I am monitoring all the signals the extra module would be monitoring, I might be able to handle that part my self (via the boost mobile phone sending SMS to my main cell phone.)
    Definitely MUCH more information to work with now. Thank you so much for your help!
    Scott
    From what I have seen, the only difference seems to be the remote and the antenna with an upgrade to the alarms software. I do know that there is also remote paging modules available (from audiovox) that acts like OnStar (TM). You would just have to figure out how to integrate it yourself since it is not a audiovox alarm.
  2. #62
    Dec 2006
    Extremeproaudio,
    Couple of questions for you (since you seem to know quite a bit about my system) First of all, is it possible to get a remote with more than the 4 buttons to use my extra channels (without having to press combinations?) and would a remote from another manufacturer work with my system if I trained it?
    Thanks again,
    Scott
    I know alot about the system because I have the same system in my vehicle Four buttons is the most you will find on any aftermarket remote. Also, each manufacturer uses different frequencies and codes for security. I do know that if you turn code hopping "off" (everytime you press a button to transmit, the security code changes in sync with transmitter and receiver), you could probably build a device like a LCD remote or something to transmit on the same frequency and have the receiver learn the new "remote". I have replaced customers three button (lock/unlock, rem start, trunk) remotes with four button (separate luck/unlock like yours) for different models that didn't offer four button remotes.
    Also, I could check tomorrow, but I think I paid $150 for my bitwriter 5 years ago. All I do is buy the upgrade chip ($10) for the newer software models.
  3. #63
    Oct 2006
    If somebody breaks into your car and can't get away with your equipment most of the time they will just destroy it out of frustration, I've seen people do some crazy jobs of securing their equipment only to get in their car and see their subwoofer has been stabbed repeatedly with a screwdriver. Once somebody is in your car, there is really nothing you can do to save your stuff.
    In my mind the most important aspect of keeping your stuff secure is quite simply keeping people out. Keep a stock exterior appearance, have a ridiculously loud car alarm with lights and flamethrowers, toxic gas release, self destruct, whatever you can dream up.
    If that fails all you can really do is ID the thieves and hope they get busted, this is where your video system would come into play. Two way alarms are nice for knowing when somebody dinged your car with their door or when some kid hit your car with a soccer ball, but if my alarm goes off and I see somebody breaking into my car I'd rather just replace and rebuild than risk my life over an entertainment system.
  4. #64
    Jan 2006
    Michigan
    Just to be goofy for a moment in my own thread. How about a flip down stereo cover. When they flip it up, I had removed the stereo and put a pneumatic boxing glove...like in the cartoons? Might even end up with some gold teeth that way! Might even be profitable for me!
    Ok, J/K...off to work
    Scott
  5. #65
    Newbie MRVJ245's Avatar
    Dec 2006
    SYDNEY!
    have a fold down compartment that you have a pittbull in
    they get in, while the alarm is armed and the compartment opens
    For Bootscreens click Here
  6. #66
    Maximum Bitrate Ruffy's Avatar
    Sep 2006
    Georgia
    how about this for an alarm setup. Upon triggering the alarm the car fills with thick foam Good luck ripping a sub out when your fighting with an endless supply of foam! Mwuahahahha
    In reality as its been said, if you make it hard for them then they will just destroy the equip. Best step is to have an alarm thats so annoying no one would bother. 12 sirens blasting at 120+dB and a freaking strobe light makes things uncomfortabe fast. Course, if someone truly wants your gear and they have the conviction you aren't going to stop them.
    I thought about recording and all that but passed on it. I'll get a nice paging alarm setup, add a few more sirens, Secure my equipment and throw a trunk monkey in the back
    Car : 00' Chrysler 300M
    Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
    Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
    CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
  7. #67
    Jan 2006
    Michigan
    MRVJ245,
    Of course, then, I need to find a way to keep the pitbull watered, fed, **** and ****ed. Not to mention air conditioned and heated. (Can't have PETA called on me!) Of course, with my own microcontroller...
    Actually, I do have a huge boxer who is quite aggressive towards unknown people. And he IS a major PIMA with his stubbornness and shannanigans.
    Maybe I could just keep him the trunk!!! Have the back seats drop down! Now just to write my code! My own DIY 'monkey in the trunk.' I might have to write an instructable!
    Scott
  8. #68
    Dec 2006
    SYDNEY!
    yeh i got a Pitty that hates water,
    yet when someone threw me in the pool and jumped in, he dived straight in and bit his ***
  9. #69
    Oct 2006
    You should do something like this...
    http://www.caraudio.com/forum/showth...ght=loud+alarm
  10. #70
    Jan 2006
    Michigan
    Damn, spoonraker! Fookin' crazy!
    A comment on there did give me an idea, though. If I can find extra space in my carpc and screen, I could install one of those personal panic alarms in it. It would go off after being disconnected from the constant 12V for a certain amount of time (like 20/30 seconds) without being disabled somehow. Imagine the look on thier faces when they sneak out of my car after jacking it, trying to be all stealthy in thier get away and suddenly WAH WAH WAH!! Tha would attract ALOT of attention! And if the cops were coming around the corner, they couldn't really act like they weren't doing anything wrong!
    And with the video system, I would get to see that look on thier faces! Might find my system smashed to hell all over the street, but at least THEY didn't get it either!
    Scott
  1. Escalade PC and Audio System Install
    By accentsound in forum Car Audio
    Last Post: 11-02-2005, 12:50 PM
  2. Trouble with PCI video card install ... help!!!
    By DonkeyBoy in forum General Hardware Discussion
    Last Post: 08-10-2005, 05:22 PM
  3. new security system for the car
    By Cartunes in forum Off Topic
    Last Post: 11-10-2004, 07:36 PM
