Do you perhaps know of a cheap online vendor that sells them? Or should I look for them at radioshack?Originally posted by Aaron Cake
Yes, shielded cable is definitly worth it.
Grand AMplifier Project 1.0:
http://drive.to/cliffsgrandamgt/
http://www.astallaslions.com/carmp3/
-Eden 800 mini-itx motherboard
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
-PB Remote /w Girder
-Media Engine & Windows XP
-Playstation II also added
-Steering Wheel Buttons modified for Control.
You could always build them yourself- grab some shielded cable and some phono plugs. Its dead cheap, and tends to work pretty well at removing hums - I use it for long video runs to stop interference or colour bleaching.
Cheers
Andrew
Mediabox Hardware Project
Current Stage: A complete redesign, although not much happening right now!
Mediabox Software Project
Status: Writing Sync Software (still) and playing around with interface
To do: Far too much!
Wait, did I miss something? Build them myself? If I were to try and build sheilded cable myself, then why would I buy sheilded cable...forgive my ignorance
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
He means buy shielded cable and solder the plug on yourself. If you do this, you can manke the cables as long as u need. Ignorance forgiven.![]()
Sorry - being dumb again! Mike got it right - get some shielded cable from a hifi or electronics store and solder a plug on the end - it should help to get rid of interference.Originally posted by Cliff
ok I am still a bit confused - I was under the impression that sheilded cables are regular RCA cables with thicker isolation all the way down the wire, but it sounds to me like the sheilded difference is made at the ends of the wires, is this correct?
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Ok, a quick lesson in Shielded cable...
Have you ever seen coaxial cable?? This is the stuff that connects your tv to your aerial (at least in the uk n e way...). It has a central core which has a little bit of plastic insulation round it. Then, there is an outer "shield". This shield is a wire mesh of little tiny strands of copper that run inside the insulation of the wire. This wire mesh or shield helps to protect the cable from interference from other sources such as rf and em radiation. As cars are a particularly noisy (electrical sense not audible) place, shielded cable is a good idea!
Do a search on google for more info
Cheers
Andrew
I also have this noise problem,and I'm using SB Live. The noise is starting only when Windows is booting,it means I hear noise only after 15-20 sec of boot,so it can't be grounding problem,I disabled everything that I don't use - mic,line in,but nothing helps...
