Results 1 to 9 of 9
Thread: Booting Issues
    Mar 2005
    Booting Issues
    ok my desktop computer is having issues.
    the problem started happeneing after 30 mins or so of heavy activity, the computer would lock up. totally freeze, not blue screen style. Sounds would get stuck and everything. I reinstalled windows xp and the problem still continued. Soon the ocmputer would osmetimes finish booting up to windows, and sometimes not. After booting in windows it would lock up the second I started loading up anyhting. Then a few months ago it wouldnt even finish booting Bios (everyhting would power up, and ten die withing 4secs). I got frusterated and stoppe dmessing with it until now.
    I tweaked the power supply a little, and now it will stay running for awhile, but now nothing is displayed on the monitor (monitor stays in stand by mode). All fans turn on and HDD Spins
    -tested monitor with laptop, and it works fine
    -swapped gfx card with 3 agp cards, and tried 4 different pci cards
    -checked all connections
    -moved memory around in different slots
    -tried booting from 2 different hard drives
    and none of this has fixed this problem. Does any one have any ideas as to what this would be? I was thinking either CPU or MB. Is there any way I can rule one or the other out?
    a few thigns abotu the system
    -nvidia gfx card only has about 1 month worth of use
    -power supply only about 6 months
    -hdd is abotu 1-2 years and the other is about 4 years old
    -Asus MB (5 years old)
    -AMD XP CPU (5 years old)
    -optical drives and floppy are disconnected (have tried with them connected same issues)
    any input is appriciated.
    Elsewhere
    Sounds like it's overheating.
    How about the Wiki?
    Mar 2005
    all fans are working, even the one on the gfx card.
    _
    Mar 2004
    Little Elm, Texas
    what are your temperatures though? just because they are working doesn't mean they are adequate
    Jan Bennett
    Mar 2005
    not sure, I dont have a temp gauge on my computer, and I cant open Bios on the fact that I cant see anything on the screen. Also how would it heat up in like 1sec and not begin boot up, but jsut stay on?
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    let me put in in reference to southpark...
    your pc is southpark.. and your CPU is called Kenny....
    see where I am going with this??
    Aug 2006
    Central PA
    Did you take it out of the vehicle and test it in a well ventilated area? If not post your results.
    Mar 2005
    yea this is my home computer...case open and everyhting in a cold room
    Mar 2005
    ok bought a new MB on ebay...now im looking for a Socket A AMD Processor
  1. Tutorial: Booting XP from a USB device...
    By mbkowns in forum WinNT Based
    Last Post: 03-05-2007, 10:51 PM
  2. Touchscreen Issues w/Hibernation & CNX-P1290
    By jmciver in forum Power Supplies
    Last Post: 12-20-2006, 08:48 PM
  3. xp booting issues
    By wrxeatr in forum Newbie
    Last Post: 05-19-2006, 10:30 AM
  4. Verizon Novatel 620 issues
    By MobiTekLink in forum Wireless Communications
    Last Post: 12-02-2005, 04:35 PM
  5. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 02:16 PM
