Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: New ultra small computer
    Feb 2002
    this thing looks awesome! can anyone here understand the language?
    http://akiba.ascii24.com/akiba/news/...36494-000.html
    sv24, 733mhz celeron, 80gig hd, 5.6" MA Audio tft, x10 remote, RF Keyboard.
    Feb 2002
    ok I found more information, does anyone know where you can buy this? http://www.morex.com.tw/sumicom.htm
    May 2001
    Seattle, WA, USA
    I saw a posting about this on [H]ard|OCP this morning.
    Here are a couple more links I found with additional pictures:
    http://pcweb.mycom.co.jp/news/2002/05/31/25.html
    http://pcweb.mycom.co.jp/news/2002/05/31/26.html
    This place has an "orders" link on the bottom right side of the page:
    http://www.mcjpc.com/
    Here are the pictures from this site, with more detail spec-wise in English:
    http://www.mcjpc.com/pc_parts/sumicom.htm
    -Brandon
    Aug 1999
    Upper Marlboro, MD 20772
    damn that is small....i wonder how much
    abcd-1
    Dec 2001
    Texas
    Damn, pair this up with one of these 7 LCDs and you have yourself one fine setup! Sign me up!
    Variable Bitrate Mitokondria's Avatar
    Apr 2002
    Sunny Florida
    This is what got from the babelfish translation... hope this helps
    Miniaturization of the PC which does not know the place where it stops. Those of small-sized cube condition in the head, the motherboard and the like of the 17~17cm like every week one after another while making the shop front of the ALo be crowded, this time " it enters into 5 inch bay, the rectangular parallelepiped full aluminum bear bone PC of 5 inch drive size " the Taiwan Morex (the Morex Information) from is appearance schedule. As for the Morex the bender where the PC case and the like is sold so far even in the country.
    As a small-sized cube bear bone PC agency of the Shuttle those where it appears with the GV[WFC treatment which is known are the product of the name, " SUMICOM ". This to be abbreviated of the " SUper MIni C$oMputer ", 145 (W) the ~254 (D) the ~41.5 (H) the size which is called mm very depth it is long, just at editorial staff survey value 5 inch bay drive size. First it received business from the GV[WFC, you thought it is simply 5 inch optical drive, you probably can call with the shop that anywhere, has expressed the feature directly.
    Optical drive being said, it is the face of the extent which is not manner, but it is designed in such a way that you can pull out the USB and the IEEE1394 and sound input/output foreward. In addition, when really you try comparing the CD-ROM drive and size of marketing, that " 5 inch drive it shakes and " well understands
    Motherboard. When you see carefully, the type turn, " ET41 " seems also coming printing is visible. Because it has 20 pin terminals of the ATX, even in a state where it is inserted in 5 inch bay available
    When it pulls the square prismatic " K " and pulls out, as for having gone in at editorial staff survey value 246 (W) the ~141 (D) the motherboard of the size which is called mm. Tip/chip set " FW82815 " + " FW82801BA ", in other words has become " the i815E ". The photograph facing, on the left correspondence to the Coppermine core, are thought it becomes the Socket370 and the right which 2.5 inch HDD and the space for slim type optical drive. In order and to cross the both, 2 DIMM slots are prepared, but 1st receiving around this memory, from restriction of height from the time before the small quantity only has circulated only " half height " SDRAM module can utilize the influence of frame size with the part bender make. As measure with the GV[WFC c128mb module 2 bundled is done at the time of sale, because we have assumed, if you do not search with utmost effort, memory capacity means the 256MB.
    As for tip/chip set i815E
    In order to dive to under slim CD-ROM drive, is installed the memory module which
    SDRAM module of half height
    h[^{[h for peripheral. Optical drive (it continues to the right above)
    2.5 inch HDD is installed the underneath that. Seeing, way you understand, as for interface of the motherboard the ATAPI
    When you look at the h[^{[h for the peripheral from the front, such to feel
    The sample item is on-board the VIA C3-800MHz which
    Furthermore " with the Morex operation is verified at present with only VIA C3-800MHz ", (the GV[WFC) for the sake of, whether it operates with the PentiumcIii and the Celeron for the present obscurity. As soon as in the future be able to verify correspondence, we have assumed it announces with the sight of the same company, but because power source supply has become the capacity 60W with the AC adapter, whether, which it can correspond it is troubling. By the way, the CPU socket and because there is a 28mm, the thin-shaped CPU cooler if approximately it may be able to correspond the width to " of the K ".
    Supplies the largest 60W the AC power source cable which
    Rear interface
    As for price opening. The CD-ROM and the HDD which are installed with the sample item not to belong, only memory belonging, shop front price is undecided. You say it is arrival schedule in plural shops such as OVERTOP and COM satellite 3 store. In addition as for expandability although it is not it is equal, as for 5 inch drive large bear bone PC which has the cool appearance of the full aluminum, the cube molded goods it may gather the popularity which is different. Because the first amount is the extremely small quantity, perhaps the desired person next week, the method which checks the shop front briskly is better.
    - 3+ years & still no carputer!
    - Done collecting parts
    - Currently planning setup
    May 2001
    Cincinnati, Ohio
    DITTO!
    Feb 2002
    Damn, I think I could have shat on my keyboard and made more sense than that translation!
    This computer looks awesome but I can't help but notice it doesn't have any video out.. does anyone think this would be din size? it looks a little long.
    At first I was really stoked about this machine... but the mini book (aka ezgo) PC looks smaller...
    Variable Bitrate Rireal's Avatar
    Jun 2002
    Jacksonville, FL
    I'll let you know when mine comes in, I ordered my EZGO Friday and it should be here Wednesday.
    May 2001
    Cincinnati, Ohio
    so whats the smallest computer that has PCI expansion slots? Book PC?
