Results 1 to 10 of 13
Thread: VIA EN15000 - losing VGA output signal?
    Constant Bitrate urosbe's Avatar
    Mar 2005
    Question VIA EN15000 - losing VGA output signal?
    I have motherboard VIA EN15000 with M2-ATX supply for few months now and I have experienced this problem only in the last 14 days. The configuration is the same from the beginning.
    I hibernate Windows everytime when I leave the car. M2-ATX jumpers are 5/45 (5 seconds to begin hibernating, 45 seconds to cut the power). Later I want to turn on the computer, but I see a message NO SIGNAL on LCD - Windows normally resumes and music is playing, but VGA output is disabled?
    Only manually reseting the bios (via jumper) help to solve the problem.
    Anyone with same same problems?
    Regards!
    Uros
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
    Mar 2005
    I forgot to mention, LCD is powered by 4-pin P4-ATX connector on M2-ATX power supply.
    Uros
    CarDomain
    Maximum Bitrate tn6478's Avatar
    Jun 2006
    Houston, TX
    its not a power problem but your mb is the cuprit
    Mar 2005
    What you mean by "cuprit"? If I reset bios manually it works for few days and then suddenly... in the morning I start the car and I see "no signal"...
    CarDomain
    Banned
    Aug 2006
    i had the same problem with mine never could figure it out so i just got rid of it they are coming out with a new motherboard the EX line so hopefully they fix the problem
    Mar 2005
    Man, optical audio outputs! And High Definition audio!
    Amazing
    I am ordering one... do you know how long we will have to wait till it is avaiable?
    Uros
    CarDomain
    Mar 2005
    Bad news, not excited about EX anymore
    I am deciding to buy ex15000 but I have a question about audio connectors. At first I was thinking all 6 composite connector are for audio (2 for front, 2 for rear and 2 for sub/center). But I am reading manual rights now, and only 2 of them are audio output (other 4 are video outputs?!)
    Currently I own SP13000 and EN15000 and it is quite common with 6x 3.5" minijacks audio outputs. But I can not imagine how can only 2 composite outputs works as 5.1?
    Can someone explain how it works?
    You are right, there are only two cinch connectors for stereo-out.
    In order to get 5.1 sound, you need to use the digital audio output, which is available as optical and coaxial (cinch) out.
    Modern A/V amplifiers usually have digital audio inputs.
    Oh crap, I have luck that I asked before ordering. I was so excited when I saw 6 component outputs, because I was thinking all of them are audio. I was thinking to replace my existing EN15000 with ex for CarPC use... I don't have amplifiers with digital audio input.
    Uros
    CarDomain
    Low Bitrate com2soft's Avatar
    Sep 2006
    i had the cn13000 which has the same display chipset as EN. the problem is the same like yours. it is a bug of the bios. my solution is to use XP's default display driver instead of the via driver.
    bios version is 1.07 on my board.
    also via is slow (or incapable) of writing a driver for 800x480 lcd.
    Maximum Bitrate JimmyFitz's Avatar
    Nov 2005
    Austin, Texas
    I have seen this too
    I have been using an SP13000 mobo for over 6 months and I have had this happen to me about 3 or 4 times randomly. Rebooting the PC clears it up for me, but I have to open the trunk to hit the hard reset button. That is a pain in the boot.
    ~Jimmy
    Constant Bitrate ankur's Avatar
    Aug 2006
    New Delhi
    I have the same problem. It seems when the motherboard doesnt shutdown properly it tries to detect the LCD at switching on time. I noticed that it reverts to LCD in the display type in the BIOS. My lcd panel doesnt work in LCD mode, only in CRT mode for some reason. I had to revert it back to CRT everytime, till i stopped standby/hibernate and now i just shutdown. This way i find the BIOS retains the display as CRT ... odd i know.
    cheers.
  1. Cleaning VGA video signal
    By Destin in forum General Hardware Discussion
    Last Post: 12-28-2006, 10:17 PM
  2. Possible to flip VGA signal 180 degrees??
    By Glyn in forum LCD/Display
    Last Post: 01-06-2004, 11:07 PM
  3. Amplifying the VGA signal...
    By WakeAndSno in forum General Hardware Discussion
    Last Post: 11-20-2001, 08:48 AM
  4. LCD signal differences - composite vs. VGA
    By laxrox in forum LCD/Display
    Last Post: 11-12-2001, 02:15 PM
  5. How to wire up a tft screen to analogue vga card
    By darkwingduck in forum General Hardware Discussion
    Last Post: 01-12-2000, 09:01 AM
