Results 1 to 10 of 20
Thread: usb-parallel?
    May 2000
    Ft Gordon, GA
    Question usb-parallel?
    does anyone have any expierence with usb to parallel adaptors? i am hoping to use it to hook up an lcd (VFD actually). any help would be greatly appreciated.
    etrik
    "if everything is under control, you're not going fast enough!"
    Maximum Bitrate CrazyLittle's Avatar
    Jan 2002
    Oakland, CA
    Post
    I severely doubt that they'll work. LCD displays need hardware access to the printer port (hence why there'd LCD problems under NT/2k/XP)
    All USB devices by nature are software driven.
    Jul 2000
    Ottawa, Canada
    Post
    i was hoping to do the some.. put a hub in the dash and run a parallel for the LCD, a USB sound source, and a USB keyboard.
    Anyway - i would think that USB software would emulate a LPT port. And you could just point the plugin there.
    anyone using one?
    [SIZE=1]'91 Nissan Stanza
    [XXXXXXXXXXXXXXXXXXXX] XX% Completed -
    Car Totaled and i bought a 20G mp3 player
    http://machs-fuel.tk
    a DIY video projector page
    May 2000
    Ft Gordon, GA
    Post
    i have used them sucessfully with printers in the past but am unsure about an lcd. guess i'll just have to try and see. i'll let you guys know how it works
    Rob
    Rob is offline
    Maximum Bitrate Rob's Avatar
    Aug 2001
    Missing In Action
    Post
    Have a look at this site I havn't used these chips but I've been thinking about using them as they seem a pretty cheap way to add more ports.
    Throught work I've done a fair bit of interfacing to LPT & Serial ports and I've got most things to work with USB adaptor, but that's under Linux.
    You can get round the writing to the port problem by using a dot matrix printer driver to interface to the port, althought you have to tie the busy pin to ground to fake the handshaking.
    And you say people actually pay money for M$ Windows?
    www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
    Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
    Jan 2000
    Atlanta, GA
    Post
    I have a USB->Serial Adapter and maybe you could plug that into a Serial->Parallel Adapter.
    Jul 2000
    Ottawa, Canada
    bump.
    etrik - have you tried this out yet?
    Apr 2001
    Here, There, Everywhere
    ugh, that sounds messy!
    it should work, but hardware access like CrazyLittle will be a problem. Unless the USB software drivers emulate the hardware port? is that possible?
    Project - GAME OVER :(
    May 2000
    Ft Gordon, GA
    sorry havent got to try it yet. Just when im getting close to having my project done, i blow my damn alternator!!!! wow am i ****ed. ok im done venting. as soon as i get a new alternator i'll try the usb- parallel interface (if i can find one that isnt usb to centronics)
    Mar 2001
    Perth, Australia
    that usb thing looks okay, but all it really is doing is changing the connector, you are still using the parrallel port/serial port.
    but im curious about how you said using a dotmatrix printer driver. does this work properly? and is this for win2k/xp ?
    caus right now im using a port95 driver, which gives direct hardware access, but lortys dont work with it and lcdcentre only works on first 2 lines. but using program lcdsmartie it works fine.
    id really like to get lorts working in 2k/xp though, so have you tested that?
