Results 1 to 7 of 7
Thread: Back up camera
    Oct 2006
    Back up camera
    I did a search but could not find my answer. I have a backup camera, and know how to hook it up to my Xenarc 700tsv, but how do I make it so that it comes on automatically when I put the car in reverse. I have heard people power the camera to the reverse lights. I would like to be able to turn the camera on while I am driving though. So how can I get it to overide the computer input when it is in reverse, and also be able to switch it on whenever I want? Any help would be appreciated.
    Constant Bitrate legacy05gt's Avatar
    May 2005
    Georgia
    There are video switches that come with a reverse toggle switch that gets tripped by your shift knob.
    I"ll see if i can find one online.
    EDIT: Heres an example of a switcher w/ a toggle on it:
    http://store.theelectroniccompany.com/sv-7020.html
    Progress:99% not 100% because theres always something to do...
    Centrafuse on XP (lited)
    EN15000
    120GB 2.5" SATA HD
    1GB DDR2 Ram
    M2-ATX PS
    Slot-Load DVD
    BU-353 GPS w/Mappoint 2k6
    DWW-700M
    Oct 2006
    Thanks for the help. I am not sure if it will work for my application however, because I also want to be able to use the camera while driving and not only in reverse. Any tips?
    Mar 2006
    Colorado, but Canadian!
    Well put the power to the camera on a toggle switch.
    When the switch is flipped up, a constant power line goes to the camera meaning the camera turns on.
    When the switch is flipped down the power comes from the switch thing in the gear knob. If the gear is in reverse, then the power goes through and the camera is on. If the gear is not in reverse then the camera is off.
    If the switch is flipped up meaning always on it won't matter what gear you put it in. Meaning if the switch is doen and you are driving, then you flip up the switch the camera will go on.
    1.9in x 2.9in -- 47mm x 73mm
    Mar 2005
    um very easy, and very covered on thiese forums
    get a 3 way senter off switch
    wire the center leg to teh camera, one leg to the reverse ligths, ther other leg to +12v
    Mar 2006
    that works too. Cheaper then getting that gear gizmo too.
    Oct 2006
    Quote Originally Posted by greenman100 View Post
    Thank you. I wasn't able to find this in the forums, so sorry for the repost.
  1. Wiring help for Rearview Camera
    By maxxell in forum Newbie
    Last Post: 08-05-2006, 03:23 AM
  2. rearview camera for car, through xenarc 7" touch screen
    By Stillalive2029 in forum General Hardware Discussion
    Last Post: 07-13-2006, 06:34 PM
  3. camera question....
    By Tripp in forum General Hardware Discussion
    Last Post: 04-16-2005, 01:49 PM
  4. why is my backup camera not working with my capture card?
    By nappyjim in forum General Hardware Discussion
    Last Post: 02-17-2005, 03:52 PM
  5. 120 deg Wide-Angle Rear View Reverse Camera off Ebay - REVIEW
    By tbird2340 in forum The Review Palace
    Last Post: 01-11-2005, 04:30 PM
