What connector do I need to hook up a cig lighter jack to the power cable?
If i bought this cigarette lighter jack http://www.partsexpress.com/pe/showd...ID=6456&DID=7, what kind of connector do I need to hook up 12 guage power wire to it? Also, do I have to ground the jack?
You can use quick connects to connect to those lines, or you can solder directly to them. 12 guage wire won't solder that easily tho. The ground is the outside of the jack.
BEN
So I don't have to run a ground wire from the cigarette lighter jack?
Both +12 and ground must be hooked up to the cig lighter.
Although, If you require 12 guage cable, you might want a better connector than a cigarette lighter.
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
