That plug that you have (the cable from the old computer) is not a standard cable.
This is the standard pinout:
You won't be able to use the connector you have (the old one) because the 3rd or 4th row of pins will be blocked meaning it won't work. All VIA boards should come with a back panel connector. Basically goes where the PCI cards screw in and has the appropriate cable already (usually the same colour as the header too in your case yellow).
LinkBack URL
About LinkBacks
And with this I'm guessing I would have to splice the wires to match the pinout?
