Results 1 to 10 of 14
Thread: Extending Ide CD-Rom ribbon cable - pics
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Just threw this together to see if would work. I had read that it could be done but i could never find pictures.
    Doing this is really tedious, i almost went blind working with all those tiny wires.
    It is not all the way done but IT WORK! I can say for sure you wouldn't be able to tell the difference as far as reading data off a cd/dvd. Dvd movie playback was choppy but it could be because my system isn't optimized to play DVD's.
    Anyway, here are some pictures
    Sep 2006
    War-Town, GA.
    some more..
    Mar 2006
    Colorado, but Canadian!
    never seen so many pictures of a wire!
    If it works good for you. I think your DVD playback is because of the length. The longer the cable, the more signal loss so there is more data being resent.
    Just how long is the final product? 48" is about the longest I was able to make that was useable. After 36" I started having data loss. 48" was only good for data transfer and not for realtime streaming. It took a lot longer to transfer multi-gigabyte files.
    Also, usually it is easier to cut only 1 wire at a time on each side. Then it is just a quick solder and cut the next wire. 10-15 minutes that way! Good solder and patience practice though!
    1.9in x 2.9in -- 47mm x 73mm
    _
    Mar 2004
    Little Elm, Texas
    internal resistance in the cable is the biggest issue.
    Why not just get an external USB or Firewire case? Would have made things much easier...lol
    Jan Bennett
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by 2k1Toaster View Post
    40 to be exact! I peeled the jacket of each one of those wires (including the CAT-5) with my front teeth!
    I did it for the hell of it (i know about USB) Ide Wire Extension - Xbox but never again!
    Ah! she's about 4 1/2 feet and the bundle of cat-5 is almost equal to the circunference of a nickle...
    Mar 2006
    you should go for an active IDE cable that is like 100ft long with little data loss! Make yourself a new world record!
    May 2005
    Wouldn't it have been easier to get a roll of that cable and a couple of connectors?
    Mar 2006
    Quote Originally Posted by sebberry View Post
    easy isn't fun!
    Aug 2006
    Bendigo/Victoria/Australia
    I hope thats shielded UTP your using there. Not much power from ide device, makes it more affected by signal attenuation. if it's not SUTP, make sure its well away from your power cables!
    Sep 2006
    War-Town, GA.
    Nope, it isn't shielded, just plain UTP as opposed to STP. If i use it, i'll keep what you said in mind. Thanks.
  1. Ribbon cable question
    By 96TransAm in forum LCD/Display
    Last Post: 09-05-2006, 12:30 PM
  2. 13 foot IDE ribbon cable?
    By cheerio in forum General Hardware Discussion
    Last Post: 08-24-2004, 01:59 PM
  3. just finished 15 foot ide cable for front cdrom
    By el bob in forum General Hardware Discussion
    Last Post: 05-09-2004, 02:37 AM
  4. Glove box mounted laptop DVD-ROM using 15 foot IDE cable pics.
    By LESLIEx317537 in forum General Hardware Discussion
    Last Post: 01-08-2004, 02:03 PM
  5. Replies: 2
    Last Post: 02-21-2002, 12:18 PM
