Results 1 to 3 of 3
Thread: SP13000 firewire problem.
    Newbie Doogle's Avatar
    Jun 2006
    Sherwood Forest
    Hi everybody
    I've got my CarPC working fine in my car, has been for a while now.
    I noticed that there are firewire header pins on the motherboard (SP13000) that I would be able to use to include a firewire port with my machine, but the pins are the mirror image of every single firewire cable I've seen. Is this an accident at the manufacturer or a deliberate change from the standards so that we would have to buy a firewire cable from via or something?
    The onboard pins are like this:
    Code:
      o
    o o
    o o
    o o
    o o
    instead of the normal
    Code:
    o
    o o
    o o
    o o
    o o
    I did manage to find a firewire cable that had individual cables to plug into the pins, but it stopped working after about 20 minutes and then I'd need to reboot the PC to make it work again, which is pretty useless.
    I currently install a PCI firewire card each time I want to put more music onto my CarPC, I use the firewire as a network port and use tightVNC to view and control the CarPC through my home machine.
    Does anybody know what else I could try?
    Getting back into the game...
    Feb 2006
    Vancouver, BC
    http://resources.mini-box.com/online...000-manual.pdf
    If you checkout the manual online it gives the pin configuration for the firewire cable. If you align the wires in the plug to match the pins it should work properly.
    Jun 2006
    Sherwood Forest
    I'll have to try and find another cable that ends in just the wires then, either that or cut up one of the block ones I've got, damn things.
    Every other motherboard I've got or seen has the pins set up the other way around, as do all of the firewire cables I've seen so far
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  3. Weird problem with DSATX and SP13000
    By arawas in forum Power Supplies
    Last Post: 01-17-2006, 08:26 PM
  4. Weird problem with DSATX and SP13000
    By arawas in forum General Hardware Discussion
    Last Post: 01-15-2006, 05:59 PM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
