Well the least amount of pins you would use for a only out connection would be ground and DataSend. For a minimalist send/recieve then just ground, dataSend, and dataReceive.
Also you won't be able to control a relay directly from a serial port. You will need to use a transistor to ramp up the voltage and then send through a relay.
What happened to that board everyone was checking out earlier with all the LED's?
Also do you want to turn the relays all on or all off, or do you want to control them all individually from the PC?
LinkBack URL
About LinkBacks
