Results 1 to 10 of 10
Thread: bit of a wierd one but amps/power
    Feb 2007
    ok i have an amp and sub that was using in a mates car, i now have it back and just wanna test it all..
    i have a car battery charger that i found in the garage (new)
    i linked it up crossed the rem with the 12v line, but it cuts out into the protection...
    i tried various things i.e taking the black negative from charger out of the ground (on amp) and then linking a power capable cable from that too a radiator, a skrew into the skirting metal on my wooden window etc
    and into a the ground pin on a plug socket into a wall...
    one attempt onto metal contact i got a bit of power untill i let go then it went back to the protection cut off...
    can anyone shed some light onto this for me please
    x
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by klimite View Post
    Most battery chargers can't put out enough stable current if the amp is actually pushed.
    i tried various things i.e taking the black negative out of the earth socket linking a power capable cable from that too radiator, a skrew into the skirting etc
    are you saying that you wired up a power cable from the ground cable to the radiator of your car? what are you talking about with skirts?
    and into a plug socket into a wall...
    HU?!!!?!?!?! Are you saying that you plugged in your amplifier to the wall socket?!
    Perhaps if you can clean up your post to where it's understandable I'd be able to help more.
    Jan Bennett
    Aug 2005
    Pennsylvania
    Im pretty sure it goes into protection because there is not enough amperage through the battery charger. Have you tried it through your car battery?
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    always remember that electronic circuits rely on keeping the smoke inside the box. If you are hooking up a ground through the radiator and even up to a wall socket ground- that smoke is just beggin to be released.
    for testing, you should be able to hook up the ground lead to the negative battery, the positive to the positive, and remote to positive to turn it on. No exotic grounds needed. Like they said before me, use a battery not a charger. A lawnmower battery or motorcycle battery should also work so long as it is a 12v.
    2005 Ford Focus ST
    _
    Mar 2004
    Little Elm, Texas
    Quote Originally Posted by gospeed.racer View Post
    I was thinking...maybe he's refering to the heat sink on the amplifier as the radiator?
    even still, that's an incredibly strange way to go about doing it.
    Jan Bennett
    Feb 2007
    no no no, sorry it's not in a car now, this is in my room hahaha..
    sorry i thought it was fairly clear :S
    yeah we have a battery in the garage i will get it in tomorrow
    i can't be bothered to move of lift it all about now i put the sub back into my cupboard an tidyed up ...
    it was so i can get power into the amp n test it all...
    _
    Mar 2004
    Little Elm, Texas
    I still don't understand what you're saying...
    Jan Bennett
    Feb 2007
    The sub and amp WERE in the car, they were removed a couple days ago by someone else...
    i wanted to test it/see what it's like on my soundsystem
    but i couldnt get it to power correctly...
    but tomorrow i shall try the car battery i have in the garage..
    all this testing is IN MY ROOOMMMM not a car now...
    _
    Mar 2004
    Little Elm, Texas
    hu?
    Jan Bennett
    Feb 2007
    This Thing is in my room, i was saying that i shall try what was said the day after because i had tidied it all away ..
  1. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 07:39 AM
  2. I need to vent a bit...Micro$haft....
    By gospeed.racer in forum Off Topic
    Last Post: 10-13-2004, 05:54 PM
  3. 8 bit ss cmos???
    By BraGa in forum LCD/Display
    Last Post: 05-07-2004, 11:35 PM
  4. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 12:08 PM
  5. Sproggy psu a bit cheaper & easier
    By TDMP3 in forum Power Supplies
    Last Post: 08-04-2002, 02:29 AM
