Results 1 to 5 of 5
Thread: Do i need another fan..or two?
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    When this case is done, it will have a cover with just the opening for the CPU fan; the bottom will also be covered partially. I'm thinking about putting another fan attached to the cover but I'm undecided whether to have it pull air into the case or exhaust it out of the case. I also contemplated putting two smaller fans on the side; one intake and the other exhaust..
    Appreciate any advise/comment
    Elsewhere
    It couldn't hurt.....
    I think it would be a good idea, TBH.
    How about the Wiki?
    Sep 2006
    War-Town, GA.
    Pushing or pulling?
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    both.
    one pushing the hot air out and one pulling in the cold air...
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Dec 2006
    Auckland, New Zealand
    Quote Originally Posted by IC-C30 View Post
    both.
    And I'd suggest that if you can track down the specs on the fans, to arrange them to have the fan with the higher CFM (cubic feet / min) doing the pushing. This will mean that you have more air going into the case than coming out of it which can go some way toward creating positive air pressure inside the case which in turn will assist in forcing dust out.
    Fan filters are a good thing, but they do increase turbulence which means more noise. It's a toss-up between clean internals and a noisy PC, your mounting position and ease of removal for periodic cleaning will help make that decision for you
  1. Cold weather, chassis cooling fan problem
    By blazini in forum General Hardware Discussion
    Last Post: 11-08-2006, 07:55 AM
  2. Hacking into Fan speed switch...
    By Dexter in forum Hardware Development
    Last Post: 07-12-2005, 12:11 PM
  3. Fan problems on my carpc
    By JohnChimpo in forum General Hardware Discussion
    Last Post: 12-10-2004, 09:25 AM
  4. Do you need a very compact graphic fan controller?
    By more mods in forum LCD/Display
    Last Post: 09-24-2004, 07:17 AM
  5. Case fan modified. Safe?
    By cafn8 in forum Off Topic
    Last Post: 03-18-2004, 11:57 AM
