how long is the usb cables that are used w/ the slot-load?
My guess (because i have the same crap happening) is that you may have to power the slot-load rather that get its power from the USB.
well i did search and![]()
this is what i don't understand i am running mII-12000 with m2-atx
and this is my set up
usb touch screen connected stright to the motherboard as suggested, second usb port goes to unpovered 4 way usb 2.0 hub, with 2 usb devices plugged in GPS & Bluetooth receiver, the 3 port goes with usb extensions and leads to the 5v powered USB hub, the 5 V ran from the power supply itself to power the hub, and splits to power slimline slot load drive in the glove compartment, everything worked initially, but now my slot load drive isn't functioning, it powers up, ejects and functions, but it's not recognized by usb
what do i do
Yev
R. T. F. M
Progress:99% not 100% because theres always something to do...
Centrafuse on XP (lited)
EN15000
120GB 2.5" SATA HD
1GB DDR2 Ram
M2-ATX PS
Slot-Load DVD
BU-353 GPS w/Mappoint 2k6
DWW-700M
I am assuming you have tried the old unplug, restart, plug in a different hole technique? Sometimes USB devices just go nutty when plugged into the same port for too long! Stupid windows...
Other than that it could be some really simple things. I would check your 5v line just to make sure it really is powering the hub. It might have come loose so now the hub is acting on self powered mode or something.
It could even be that the drive has just been a little nudged out of its enclosure. So do like a SNES cartridge, and take it out, blow on it, and shove it back in there. While off of course!
1.9in x 2.9in -- 47mm x 73mm
R. T. F. M
