Results 1 to 7 of 7
Thread: motherboard port "hack" is EASY!!!!
    May 2002
    Sef'Kylar
    Not only is the topic a parady of THEMP3KID's post.. but it's just as insane
    As i was trying to figure out how to get my mobo in the dinbox and get the parallel port to the front for the char lcd i glaced over at an old motherboard and decided DREMEL TIME!@#!
    So I'm halfway through my computer hacking.. in the most litteral sense possible.. I just need some parts to finish it up
    Hopefully I don't trash the board!
    Once i find my adapter for my digicam i'll post some pics
    aka Kumaneko
    "Don't make me moderate your ***!"
    Maxima of Doom - project thread - photo gallery
    mp3car system is currently FUBAR and finances do not allow for a correction of that situation
    Real computer hackers use a rotary cutting tool on their motherboard.
    Banned
    Jun 2001
    Adelaide, Australia
    Ahh, one question, what exactly are you doing/trying to do??
    2 week temp ban (spam and complaining about deleted posts)
    register another account and you're gone for good.
    Registered User
    Jun 2001
    I think he just explained it, MP3KID, He is going to mount his VIA board in a car din.
    Relocating the parallel port would be the solution instead of creating a custom 6 inch cable!
    ShinkunoNamida will probably have to mount the board in a way that the i/o plugs face a side of the din rather than the dash.
    If you reread the post you can probably figure that one out.
    May 2002
    Sef'Kylar
    Well i'm putting a character display in the front.. and the ports will all be facing the back. My choices were:
    to flop a cable back into the box from the outside "ew ugly"
    to turn the board around "ok but now i have to reroute some ports tot the back.. and now there's a lot less free realestate in teh front"
    cut the bloody thing off and wire the lcd directly "hmmmm this sounds scary, but exciting!"
    rather than trying to unsolder the parallel port.. since i have little faith in my soldering skills.. i cut away enough of the parallel port connector to pull it off and be left with the pins.. which i'll solder to then isolate with shrink tubing
    I have much mor faith in soldering to these things than to the little hole right next to eachother
    aka Kumaneko
    May 2002
    Malaysia/Great Britain
    Man! i pity your mobo......hehehe. Best of luck!
    Paladin
    Banned
    Jun 2001
    Adelaide, Australia
    Yeah, I figured someting like that, but what were you saying about the old mobo?? also, couldn't you just extend teh case by like 1cm, so all the sockets were recessed, with a slightly larger cut out for each, but no cut out for the parallel port, and run a acable internally.... understand?? So, all teh other cables would go through their own holes in teh back of teh case, and plug straight into their sockets, but teh parallel port would have no hole..
    May 2002
    Sef'Kylar
    Well since the case is not going to be that big an parallel adapters tend to be relatively large (it would be about 15% of the overal size of the case!) I needed to make it a bit simpler than that.
    Seeing the old mother board I had a test subject to work on before going to my true target.
    Aside from all that.. this is just much more fun
    aka Kumaneko
