Results 1 to 4 of 4
Thread: PCI Card VS Powered Hub.
    Aug 2005
    Since all my USB devices are within reach of my CarPC (5M USB Spec). Would running a PCI USB 2.0 card be just as good as a powered hub?
    The PCI cards is powered also right? Or can the power from the bus not be as a great as a Powered Hub?
    Some guidance would be great. Trying to avoid USB headaches.
    Cheers
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by SKiTLz View Post
    Cheers
    PCI USB hubs are powered through the PCI bus.
    The only advantage of a powered USB hub from anther usb port, would be size and the flexability of putting it at a distance from the PC.
    But for your needs, a PCI version should work. Just make sure to glue it down or something so the contacts don't loosen or grind off.
    1.9in x 2.9in -- 47mm x 73mm
    Aug 2005
    Great. Thanks for the reply.
    When you say glue it? You mean glue the PCI card in the slot? What kind of glue can you use for this? I have a PCB i need to glue to the chassis as well but not sure what to use.
    Cheers
    Mar 2006
    Well hot glue works. Make sure you get the "high temperature" hot glue. It wont melt as easily when being baken in your car during hot summer days.
    Check out this thread specifically for this question: Glue and PCI slot?
  1. anybody use these? double pci riser card
    By studmonk3y in forum General Hardware Discussion
    Last Post: 07-29-2005, 10:41 PM
  2. Ordered kigwin PCI USB card - didn't recieve the low profile card bracket!
    By sivart321 in forum General Hardware Discussion
    Last Post: 07-08-2005, 02:08 PM
  3. FS: Black 13.3" TFT LCD and PCI controller card CHEAP
    By Riverdale in forum Classified Archive
    Last Post: 12-09-2004, 11:07 PM
  4. PCI Video card not working
    By TX5 in forum General Hardware Discussion
    Last Post: 10-10-2004, 11:56 PM
  5. PCI card riser card
    By allenruble in forum Classified Archive
    Last Post: 11-25-2001, 08:51 AM
