Have you looked in the manual?
(Hint: It's on page 27)
I've search the forums but cant find any mention of this board. It seems to have everything I want with ability to under clock for the Athlon xp mobile 2400+ I've got but can't find anywhere that says it has S3 power save mode. Any body have any experience of this board or knows whether it has S3?
the board is
Asrock K7NF2-Raid Socket-A Motherboard
CPU - Socket A (462) for AMD Athlon XP/Athlon/Duron/Sempron™
- FSB 400/333/266/200 MHz
Chipset
- Northbridge: nVidia nForce2 Ultra 400
- Southbridge: nVidia MCP-RAID
Memory - Supports Dual Channel DDR400/333/266
- DIMM slots: 3
- Max. capacity: 3GB
Hybrid Booster
- CPU Frequency Stepless control
- CPU Multiplier
- CPU Vcore Adjustment
- AGP/PCI frequency fix
- ASRock U-COP
- Boot Failure Guard (B.F.G)
BIOS Feature
- 4Mb AMI BIOS with ACPI, SM BIOS 3.0, PnP
Hardware Monitor
- CPU Temperature Sensing
- Motherboard Temperature Sensing
- CPU Fan Tachometer
- Chassis Fan Tachometer
- Voltage Monitoring: +12V, +5V, +3.3V, Vcore
Accessories - Quick Installation Guide, Support CD, I/O shield
- Floppy/ATA 133 cables
- 1 x SATA data cable
- 1 x SATA 1-to-1 power cable
Form Factor
- ATX, 305mm X 198mm
Just found the manual which talks about suspend to ram. Is this S3 power saving?
Thanks DarquePervert
