I am not familiar with this mobo, so I just can give you general ideas...
1. You said, voltages are OK. What is the power? (amperes) does it fit the range?
1.5Are the parts of the mobo producing heat? (I mean standard heat)
1.75 Is there any part that is too hot, according to your opinion?
2. Remove EVERYTHING but processor (and RAM, if neccessary). Does it have an onboard video? If not, try different video cards...
3. Discharge the CMOS. Remove Battery, wait for some hours.
4. When you have possibility to have a multimeter, try to measure the address and data pins of the BIOS ROM (or EEPROM) during boot. (high speed oscilloscope is better)
If these do not help
The symptomes could show a:
1. BIOS ROM/Flash EEPROM problem
2. General mobo problem - eg. around producing special voltage
3. Processor problem.
LinkBack URL
About LinkBacks
