INC Custom Calbe
Micro Computer Cable Company
Pacific Cable has helped me before, but they had the parts in stock.
or
If you can see a name or number on either connector, that would help you out a lot!
Hey all,
I have been reading this site for quiet a while now and have picked up some absolutely awesome tips. This is my first question however. I need to find a bit of cabling to extend from the Mobo pictured here:
To the board that was at one time attached to it, pictured here:
The cable will need to be about 6' The idea is to mount what used to sit on the laptop itself right under the screen in the dash. I have the molding all done and everything in place. for some reason I just figured it would be a simple solder and wire job but now that I see it, it isn't. Even a link to a place that sells cables would be great.
I called Molex and they said if I wanted to order 2k of them they would take the time to figure out what kind of cabling I would need but otherwise they didn't want to even discuss it. They directed me to radio shack.... It took at least 10 minutes to even get the guy to understand it wasn't a usb or vga cable.
Anyways any help would be appreciated. Thanks!
-TT
INC Custom Calbe
or
well there is a bit of lettering on the male end. one side says pa6t (seems to be a type/brand of plastic) and on the other side in which almost looks like someone scratched it in by hand is NAi$ 016 how ever the A is more just like an upside down V. I goggled both and came up with very little, even less in English. I will check out those sites and see if I can find what I need.
Heres a picture of the back of the board, I kind of doubt any of this will have to do with the actual connector but maybe it would help.
-TT
