Results 1 to 3 of 3
Thread: Sirius FM Adapter to Monsoon Radio 2003 JEtta
    Feb 2007
    I am currently in the process of adding a sirius satellite radio to my stock 2003 VW Jetta with the Monsoon stereo.
    I purchased the FM Direct Adapter for the Starmate 4 radio and wanted to know if anyone has had any experience in removing the Head unit from the dash, and connecting the adapter to the antena cable to the back of the unit. I have looked for literature on this matter on the web and have found nothing.
    Does anyone have diagrams or experience in how to do this?
    thanks
    Mar 2006
    Colorado, but Canadian!
    Well we are CarPC people, so most of us use a USB circuit and connect to our computers that way, so most people around here including myself will be unable to help you. I suggest a forum either specific to your vehicle, or specific to the adaptor you bought.
    My guess is since it is "FM Direct" that it emulates a radio station and you just tune in to the frequency on your HU to get that sound to come out. So I would assume it has a antenna in port and an antenna out port. Basically one side with a hole to accept the stock antenna, and then a cable out the other end to plug into the HU. So just select what frequency you want that module to tune to (usually a slider switch with wireless ones, so probably similar on the direct versions) and then plug it in. Done.
    1.9in x 2.9in -- 47mm x 73mm
    FLAC jbors's Avatar
    Nov 2003
    You will need stereo removal tools. Sold on many sites from $5. Then insert 4 of them into your stereo and pull it out. Simple as that...
    I would recommend throwing away modulator and get direct input adapter. They go from $40 on ebay. You won't regret
    Car pc integration with ease
    Car mediacenter
  1. CarPC Remote control of FM Radio / Amplifier within Blaupunkt HU
    By ProCos in forum General Hardware Discussion
    Last Post: 05-28-2011, 10:56 AM
  2. FM Radio support? Ever?
    By senseless228 in forum Mobile Impact
    Last Post: 03-13-2007, 09:21 AM
  3. FM Radio on carputer?
    By reapur in forum Newbie
    Last Post: 08-15-2006, 11:31 PM
  4. FM Radio Input Via Aux Line
    By 2muchwires in forum Newbie
    Last Post: 08-08-2006, 04:27 PM
  5. FM CF card
    By Twopoint in forum Car Audio
    Last Post: 07-18-2004, 04:44 AM
