Results 1 to 5 of 5
Thread: cpu cooler touching case
    Newbie Touran's Avatar
    Feb 2006
    I'm planning to get a bigger cooler for my cpu (AMD geode) I want to make it as big as possible but have little room (3.5cm above) So I'm planning on buying a bigger one and customizing it for the room I have. Would it be dangerous for the CPU if the cooler would touch the metal casing??? Like short circuit or something?
    the case looks like this http://www.picco.nl/product_info.php...oducts_id=1854
    Elsewhere
    You need a cooling fan on a Geode?
    I thought they were supposed to be uber low-power/low-heat, similar to the C-3 on the M10000....
    Overall, a heatsink touching a case would likely vibrate. That would be annoting, at the very least. It could also work the heatsink loose, at the very worst.
    How about the Wiki?
    Maximum Bitrate DeltaFX's Avatar
    France
    Yep, if that Geode is a NX, he needs a heat sink ( GeodeNX = Athlon thunderbird at same freq, with 1/5 of power of a thunderbird)
    Now Galileo is real. Muhahahahaha :p
    Nov 2006
    electrically, you *should* be OK, as the motherboard is grounded to the case, but I always try to avoid things like that if I can
    Just leave a small gap (like 1-2mm). You won't lose any performance, and you'll have piece of mind
    Maximum Bitrate psyrex's Avatar
    Jun 2005
    Oakland, CA
    stick a piece of electrician's tape on the case where the heatsink will touch it. I second the vibrate/rattling comment, though.
    Gen 1: Pentium 3 1GHz - ATX - 2005
    Gen 2: Pentium M 1.6GHz - ITX - 2006
    Gen 3: Pentium M 2.0GHz - 5.25" SBC - 2007
    Gen 4: (coming soon: Core2 Duo - 3.5" SBC - 2009)
    ...it never ends
  1. Opus CarPC Case .. anyone have it?
    By replicant in forum General Hardware Discussion
    Last Post: 09-29-2005, 07:09 PM
  2. Replies: 1
    Last Post: 08-21-2005, 01:16 PM
  3. Ampie - ITX CASE for sale
    By JRunner in forum Classified Archive
    Last Post: 08-18-2005, 12:40 AM
  4. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
  5. DIN Case Question and CPU ?
    By inothome in forum Newbie
    Last Post: 10-26-2004, 04:08 PM
