Results 1 to 8 of 8
Thread: Found this PCI audio AMP, whataya think?
    Newbie DaveWilliamsTX's Avatar
    Feb 2007
    Denton, TX
    Ok, this obviously won't blow anyone's ears off, but I thought I'd throw it up here for those of us who might be looking for a simple audio set up for our carputers:
    Cinemar AMP152 Modular Amplifier
    While it looked pretty cool, and it boasts "Room filling power" I'm wondering if it might be a little weak for even the most basic stock car stereo. Worth checking out though. If they had one that put out 40Wx2 I'd get it in a heartbeat.
    Mar 2006
    Colorado, but Canadian!
    not bad. But for $125, I would rather get a crappy little car amp!
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Denton, TX
    you would get the "all in one box" effect with it, though (if you do in-dash w/ everything else). I'll probably go the car amp route, however.
    Mar 2006
    Well they make really tiny amps such as what are used in HU's. I figure that is what this is, but slapped on a PCI spec board.
    Still good as an alternative option. Also PCI cards need to be glued down or something for car use, or they will fly away from their socket.
    Feb 2007
    Denton, TX
    On the site it doesn't specifically say 15Wx2, do you think it puts out 15 Watts total (so like 7.5x2)? If it was 15Wx2 it *could* work. How much power to most stock head units put out? <--- will look around for this now
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    that thing is a gimic. YOu could get much more power for way less money that that. THat isn't even headunit power (Most will do close to 20W with less distorion than that thing). THat is like installing a cheap set of PC speakers in the car. And that thread did not go so well...
    _
    Mar 2004
    Little Elm, Texas
    Jan Bennett
    Feb 2007
    Denton, TX
    agreed. am just going to get small car amp. It would be sweet if there was a 45Wx2 PCI amp that would run on a computer PS, alas, it isn't to be.
  1. Diamond Audio D6 1000.1 Amp help please
    By DSLKSL in forum Car Audio
    Last Post: 10-02-2006, 08:31 PM
  2. fs: jl audio 300/4 amp and jl audio subs
    By EsKALad in forum Classified Archive
    Last Post: 09-17-2006, 10:13 AM
  3. Tiny Car Audio Amp.
    By thwack in forum Car Audio
    Last Post: 08-18-2006, 10:14 AM
  4. Need some help with sending audio to stock amp
    By orangewhip in forum General Hardware Discussion
    Last Post: 09-04-2003, 01:21 PM
  5. Found the amp of my dreams!
    By Skippman in forum General Hardware Discussion
    Last Post: 07-29-2002, 09:53 AM
