Results 1 to 7 of 7
Thread: DIY computer case
    Oct 2006
    California
    DIY computer case
    I want to CNC a custom pc case for a micro-atx board to fit into a tricky spot of my car. I am looking for cad files or accurate drawings for the screw layout and connection positions. Anyone have anything?
    Mar 2006
    Colorado, but Canadian!
    1.9in x 2.9in -- 47mm x 73mm
    Oct 2006
    California
    Yup,
    That would be it!
    Funny thing - I had actually looked at matxspe1.2.pdf before I posted only to dismiss it when I saw the diagram on p10 with the note that it was not to scale and no dimensions for the placement holes.
    Thank you for the links.
    Mar 2006
    Quote Originally Posted by daregone View Post
    Yup,
    That would be it!
    I had the same problem when I was looking for itx specs. I found 1 pdf with the info and I lost it!
    Now i am looking for it again! That and the M2-ATX specifications. I have it in my car, but I don't want to unhook it to measure it. same with the mobo!
    May 2006
    Toronto
    M2-ATX Dimensions?
    Is this what you're looking for?
    mini-box.com M2-ATX PDF
    This came in handy when I was trying to get my own case designed. I only need to make a few adjustments to get the MB in and I should be close to getting this thing installed.
    Orbserver
    Mar 2006
    Yup. And I found my itx pdf, so I am all set!
    Thanks a bunch.
    Jun 2010
    post a picture!!
  1. FS: Computer System (No case)
    By CJ8501 in forum Classified Archive
    Last Post: 03-04-2006, 03:43 AM
  2. Painting Ampie Case
    By semovodka in forum General MP3Car Discussion
    Last Post: 10-08-2005, 05:37 PM
  3. Paint inside of computer case
    By TheJack in forum Fabrication
    Last Post: 02-14-2005, 06:21 PM
  4. is frodo compatible with voice software?
    By nappyjim in forum FrodoPlayer
    Last Post: 11-01-2004, 05:50 PM
  5. What case to get and where? for an ASUS Mini ITX mobo? not a DIY case.
    By BEHMER in forum General Hardware Discussion
    Last Post: 07-31-2004, 10:01 PM
