Results 1 to 5 of 5
Thread: randomly resets
    Jun 2005
    MD, USA
    randomly resets
    relevant specs: mII10k, opus120w
    i know im posting this topic right above another random reset thread, but it is different.
    everything boots up fine, everything works fine, and after about 20 minutes the carpc will just shut itself down, and power up again after about 30 seconds of just nothing. after it powers back up again it only takes about 5 or 10 minutes before it goes through the same process, evermore decreasing the amount of time it stays on with each reboot.
    now this leads me to believe that it almost has to be a heat issue. i dont think this is possible though. the case is not even warm to the touch, and it is most definitely cooler in my car right now than it was in the balmy summer.
    so my other thought is that the turn on lead for my PS is not stable. weird that it should happen now, after working perfectly for ~5 months.
    i also read while doing some searching that bad ram can cause reboots, but i really do think this is more of a PS issue.
    im going to meter the turn on lead to see if it drops down a lot. it is winter and i do have more electrical accessories running, but i would have thought i would have seen signs of this a couple months ago.
    any thoughts?
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    the PS could be overheating, thermal protection could shut it down.
    TruckinMP3
    Read the FAQ!
    Feb 2009
    I'm having pretty close to the same problem, after almost 20 minutes the computer consistantly reboots itself.
    I have not noticed a steadily decreasing amount of time between reboots, but I've only timed it a few times.
    Did anyone find a solution to this problem?
    Could be an issue with the power getting to the unit, but the consistent timing of the restarts seems odd to me for a connection problem or fluxuation of the voltage, I could be wrong though.
    Jun 2005
    MD, USA
    this issue ended up stopping, don't really remember how. i reloaded xp and re-seated everything and i'm not seeing it now.
    kind of a pain, but it's gone.
    Jun 2002
    Colorado
    Quote Originally Posted by tattooedflmfrk View Post
    Random cause really means undiscovered reason. Might be heat, could be a loose connection (card or wire) might be power.... might also be OS, check the connections and the error logs.
    TruckinMP3
    Read the FAQ!
  1. Computer resets on startup
    By Touran in forum StreetDeck
    Last Post: 02-13-2007, 01:27 PM
  2. Replies: 6
    Last Post: 10-24-2006, 09:58 PM
  3. Troubleshooters! Computer turns off randomly and wont turn on, need help
    By phatbimmer in forum General MP3Car Discussion
    Last Post: 06-05-2005, 06:09 PM
  4. Resets without reset button? I Hate them
    By ThEScReW in forum General Hardware Discussion
    Last Post: 12-23-2004, 04:19 AM
  5. Proggy/plugin to randomly sort playlist?
    By Tony S in forum Software & Software Development
    Last Post: 08-03-2002, 03:33 PM
