Results 1 to 7 of 7
Thread: Motherboard header connectors: Where do you get them?
    Jan 2007
    Calgary, AB
    I am wiring a bunch of jumpers and switches to the back panel of my ampie case and am trying to find where a good place is to buy a handful of the plastic connectors that attach to the motherboard header pins. I would also need the crimp/solder pins that are placed (housed) inside these connectors. I have found some 2-pin fan-type connectors but they are too big and only good for fan header-type connections.
    This is what I have found:
    and this is what I want:
    or like the 2-pin connector in the center of this picture:
    I have found pre-made, 2-wire connections like this but they are charging like $5 for it. I just want to make my own cables but am having a tough time finding a good source.
    Thanks.
    Elsewhere
    There is a store local to me: Altex Electronics. They have all that sorts of stuff.
    For online, there is Mouser and Digikey. For local, I suggest a locally-owned electronics shop.
    How about the Wiki?
    Maximum Bitrate Rundell's Avatar
    Some of the items you need can be bought from http://www.frontx.com/ I have used them before and never had a problem with them. Not local but atleast ships for free.
    Remember AllAdvantage From 7 years ago? IT IS BACK! Now under a new name Agloco
    GET PAID TO SURF THE INTERNET
    DIGItonium
    Guest
    FLAC evandude's Avatar
    Mar 2005
    Maine
    I use these connectors quite often, they're moderately cheap (about 50 cents per 2-pin connector, including housing and pins) - but you do (sort of) need the crimping tool, which is about $11. You can crimp with pliers if you want to save money, but I think it's worth getting the right tool if you're going to be doing very many.
    I bought all mine at Jameco - here's links to the catalog pages:
    http://www.jameco.com/Jameco/catalogs/c253/P121.pdf (sockets, crimp pins)
    http://www.jameco.com/Jameco/catalogs/c253/P242.pdf (crimping tool)
    But don't take it from me! here's a quote from a real, live newbie:
    Quote Originally Posted by Viscouse
    I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
    eegeek.net
    Constant Bitrate ZtH01's Avatar
    Jan 2006
    Mankato, MN
    Quote Originally Posted by xraycat View Post
    Thanks.
    Look for a local electronics supplier or surplus place. I bought mine at Ax-Man in St.Paul MN for like .25 a peice. They were all 2 pin, with the pins already crimped in place so no need for the crimper.
    -ZtH01
    "It's my belief that my big balls should be held every night"
    Feb 2007
    Try a local computer shop tossing out old PC cases, that is how I got mine. Ripped em out of older PC cases.
    Rc
  1. FS/FT AMD xp1800+ with motherboard +case+ PS *CHEAP*
    By bluemagic in forum Classified Archive
    Last Post: 10-17-2006, 04:40 PM
  2. Still Can't Get New Motherboard To Power Up
    By james33440 in forum General Hardware Discussion
    Last Post: 10-22-2005, 01:02 AM
  3. FS: Mobo serial header connectors
    By Viscouse in forum Classified Archive
    Last Post: 08-16-2005, 12:25 PM
  4. FS: Casetronics C134 and EPIA M9000 Motherboard
    By jusatry in forum Classified Archive
    Last Post: 05-17-2004, 05:38 PM
  5. motherboard connectors
    By adrian_uk17 in forum Power Supplies
    Last Post: 02-25-2004, 10:55 AM
