Results 1 to 5 of 5
Thread: Any suggestions before I buy this?
    Low Bitrate taylorgauss's Avatar
    Feb 2007
    Seattle
    SolidLogic C134 Automotive Mini-ITX System
    - Mainboard: EPIA M10000 1GHz
    - Case: Casetronic C134 Mini-ITX Case - Black
    - Memory: DDR266/333/400 Ultra Low Profile RAM 512MB
    - Hard Disk/Flash: 2.5" Samsung 5400rpm 120GB
    - CD/DVD Drive: TEAC Slimline CD-ROM (CD-224E)
    - Power Supply: 160 Watt M2-ATX Intelligent Automotive Power Supply
    - Operating System: None
    - Build and test: None
    - Removed Items: Original DC Converter and A/C adapter
    - If CD Drive: CD to IDE Adapter, IDE Cable, CD Audio Cable
    - If HDD: HD Converter
    If I have XP it shouldn't be a problem installing it on this right?
    Mar 2006
    Colorado, but Canadian!
    Nope, no problem. I hope you aren't paying too much for that. Since they aren't building or testing it then you might as well buy the components individually because it might be cheaper. Might want to check it out.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Seattle
    It would be $588 from them. What site would be good to buy them individually? Also do you think the processor speed is good enough to cover any of the apps I would throw at it? Of course im talking in terms of carputer programs not like photoshop and ish!
    FLAC XC-C30's Avatar
    Jun 2006
    Abele, Belgium
    really depends on what you want to do with it. There's lots of peopl running an M10K-based system. But if you want to use it for sound-processing or other kind of havy use, you're not gonna cope with it.
    Xenia & Isabelle, totally in love!
    'T SQiekenkot: VOLVO 740GL 2.3
    CarPC: none at the moment
    CLARION HX-D2
    CLARION APA4300HX => Fountek NeoCd1.0 + TB W4-1337SD
    CLARION APA4300HX => CSS Trio8
    CLARION APA2100 => Dayton IB385-8
    Newbie RoTalk's Avatar
    Jul 2006
    If you had a budget of let's say $600-700 because the other 300$ would go for the screen. What would your parts and accessories including mobo you would get?
  1. Build vs Buy...
    By plan_Z in forum General Hardware Discussion
    Last Post: 10-05-2004, 11:45 PM
  2. suggestions
    By Jaimz in forum Power Supplies
    Last Post: 09-28-2004, 05:08 PM
  3. looking to buy opus 90w
    By NUIpIsqo in forum Classified Archive
    Last Post: 09-05-2004, 09:29 PM
  4. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
  5. Where to buy seiko L4034
    By Adam F in forum LCD/Display
    Last Post: 12-27-2001, 12:21 AM
