The page you've linked to says you can power the "LED from either your motherboard's 5V DC output or your Power Supply's 12V DC output" and gives you the resistor values for each option. So your preference for powering from your mobo is acheivable. Have you tested the LED is working? (Try using a small 3.3V battery.) It's either broken or it ain't getting power.
LinkBack URL
About LinkBacks
