Results 1 to 4 of 4
Thread: Best method for wiring up 7" Lilliput
    Nov 2006
    What is the best method for wiring up the lilliput in the car? The the wires from the A/C adapter and wire it to the power distribution block? What fuses should I put in line for it?
    Elsewhere
    The Lilliput should come with an egg-shaped regulator. Wire that up to an ignition-controlled line. a 1A fuse is more than enough to protect the lilliput, considering it draws < 1A.
    Another option is to power it from your PC's power supply. Tap a HDD molex (YELLOW WIRE!) for that.
    How about the Wiki?
    Aug 2005
    Pennsylvania
    Mar 2006
    I did what Darque said and it worked perfectly. If you are confused which wire would be pos/neg on the power wire for the Lilliput take a look at the fuse that is on there. There will be a small + and - where the wires go into the small fuse "box".
  1. FS/FT: TWO 7" Lilliput Screens
    By Nico3k in forum Classified Archive
    Last Post: 10-14-2005, 07:08 PM
  2. Lilliput 7" (first model) touch function dead
    By holistic in forum LCD/Display
    Last Post: 09-28-2005, 02:27 AM
  3. FS:: 7" Lilliput touchscreen lcd
    By carfreak01 in forum Classified Archive
    Last Post: 08-29-2005, 12:47 PM
  4. Replies: 6
    Last Post: 05-18-2005, 05:43 PM
