Results 1 to 3 of 3
Thread: ide to usb recommendation needed! Not the usual questions
    Registered User vfinterceptor's Avatar
    Oct 2005
    up-the-hill-turn-left-by-the-big-tree
    Hi people.
    I need a recommendation for an ide to usb adapter.
    Now before I get search or newbee comments, here is my problem.
    I already have an ide to usb adapter for my slot load cdr/dvd, but it won't let me use a cable over 6 feet in length. And as you have probably guessed by now, the dvd is in the dash, the computer in the trunk.
    If I use the 6 foot cable, everything works normally. Any longer, be it through a powered hub or just a longer cable, the drive does not want to play. The comp recognizes it, but it will not read. It just seems to get caught in a costant reading loop (you can hear the drive cycling) and the computer gives three quick but quite beeps.
    So, I'm looking for a recommendation on a ide dvd adapter that will work on a longer usb run (about 12-15 feet or so). Preferably one someone has used and can be sourced off ebay or the like.
    Cheers
    BJ
    *edit*
    Aww, crap!
    Why is that after you finally give up and post a question, you find the answer like 2 seconds later?
    It's a power related issue. I tried hooking up the optional dc in opn the adapter to a ps2 splitter from the keyboard and it runs off a longer usb cord just fine........
    I'll have to either get a 5v source up front or figure out a way to get it there without voltage drop off.
    Feb 2007
    I have a similar setup and ran short usb cable to a 7 port hub in the dash. Then i ran a usb cable from the hub to the computer in the trunk. I hope this helps
    Oct 2005
    Thanks but i already have a fix.
    I put a powered usb hub up front and tapped power off it to run the slotload.
    Cheers
    BJ
  1. Is there an ide to usb cable?
    By Gippy87 in forum General MP3Car Discussion
    Last Post: 02-08-2007, 10:57 PM
  2. Slimline DVD + IDE adapter + IDE -> USB adapter = no drive in Windows?
    By WiCKeD 5.9L in forum General Hardware Discussion
    Last Post: 08-04-2005, 09:49 PM
  3. Slimline DVD > IDE > USB Has anyone tried this?
    By Keebortz in forum General Hardware Discussion
    Last Post: 07-11-2005, 03:21 PM
  4. basic USB questions
    By RedGTiVR6 in forum General MP3Car Discussion
    Last Post: 01-25-2005, 10:56 AM
  5. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
