Results 1 to 4 of 4
Thread: Non powered USB hub
    Feb 2007
    Pleasanton, CA
    Non powered USB hub
    hi all,
    The Epia MII 12000 motherboard from VIA comes with only 2 onboard USB ports and two more through a USB header. I am gonna have the lilliput taking one for the touchscreen capabilities, one for the bluetooth adapter for my phone and OBD2 scanner, and one for the GPS - leaving only ONE more port open. I was wondering - if I plug a non powered hub into it and plug the touchscreen control and bluetooth adapter into it - how well would that fair? Am I risking overloading the motherboards' USB outputs?
    The computer will be powered by a Mini-ATX M2-ATX PSU (160 watts).
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by ComradeJew View Post
    hi all,
    It PROBABLY won't, but there is no way to tell with out knowing more about the BT dongle.
    You can try it and see what happens.
    Michael
    Mar 2006
    Colorado, but Canadian!
    It should be fine, but I suggest the GPS and touchscreen plug directly into the USB ports on the motherboard, and then the bluetooth and OBDII through the hub. THe touchscreen and gps are sometimes fidgity when run through hubs. For no apparent reason, they just are.
    1.9in x 2.9in -- 47mm x 73mm
    Feb 2007
    Pleasanton, CA
    Quote Originally Posted by 2k1Toaster View Post
    The OBD is wireless through bluetooth... i am gonna borrow a friends non powered hub to see how it operates...
  1. Power USB Hub with M2?
    By Arty13 in forum Power Supplies
    Last Post: 01-04-2007, 09:16 PM
  2. Replies: 197
    Last Post: 06-15-2006, 09:47 PM
  3. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 12:44 PM
  4. USB Hub not working after coming out of hibernation
    By volum3rider in forum Input Devices
    Last Post: 09-11-2005, 01:07 PM
  5. Powered USB Hub HELP!!
    By evilragu in forum Newbie
    Last Post: 07-23-2005, 08:14 PM
