Results 1 to 6 of 6
Thread: Still getting alternator whine after a year.
    May 2006
    Calgary, Alberta
    Unhappy Still getting alternator whine after a year.
    So I've made it a year with a carputer and haven't burned my car to the ground yet. Who knew. Anyway, I've been getting alternator whine in my speakers and figured it was because of the location of my speaker wire near the power wire that I didn't post the question here before. So I kept the power wire running under the door sill and moved the speaker wire into the ceiling/pillars to separate the two completely. For some reason I am STILL getting the whine and it gets higher pitched when I push the gas. How is this possible? I'm using a ground loop isolator on my front and rear channels with the isolator on the amp side. Here are specifics about my setup:
    - m10000
    - M1-ATX
    - no headunit
    - speaker wire coming from speaker wire in dash to 4 channel amp, through ground loop isolators (front/rear) into on board sound.
    - subwoofer RCA cable has no ground loop isolator
    - M1-ATX getting power straight from battery via 10 gauge wire
    - M1-ATX grounded to bare metal frame along with both amps at same point.
    - 4 gauge wire coming from battery to distribution block, 2 8 gauge wires going to amps
    Need to know anything else? It's a 2005 Civic and shouldn't have any electrical problems. I searched for answers but most of the threads deal with power wires and ground loop isolators.
    Ampie Case
    256 MB DDR2 PC5400
    Xenarc 700TSV - VGA Monitor
    Intel D945GCLF Motherboard
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    Colorado, but Canadian!
    Quote Originally Posted by Maheriano View Post
    I literally lol'ed at that! Thank goodness that you are getting power straight from the battery instead of the cig lighter!
    But have you made a little ground from a motherboard standoff to a ground? That might help a little bit.
    1.9in x 2.9in -- 47mm x 73mm
    May 2006
    Calgary, Alberta
    I'm guessing no since I don't know what that means. Is there an explanation somewhere on how to do this? Is it just wrapping a wire around one of the motherboard spacers and running the wire to a ground?
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
    Mar 2006
    yes
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    the order in which you ground your devices is key here,if they're all grounded to the same point its important to have the item pulling the most amps grounded first then the next highest after that and so on.
    If their not all grounded at the same place then that could also be the problem.
    You should also keep the earth's as short as possible,in my Zafira all grounds are in the boot,together on 1 point and i have no whine at all.
    I use an M2-atx and have 2 amps totaling 600 watts.
    Its strange as i've only ever used ground loop thingy's when running from an invertor.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    May 2006
    Calgary, Alberta
    Finally fixed this 2 days ago. I had ground loop isolators on the front and rear RCA cables. Once I removed one of them and used just a regular RCA cable the whine is gone.
    Plus about a month ago I re ran the speaker wire along the headliner and away from the power cable but at the time it didn't change anything.
    Ampie Case
    256 MB DDR2 PC5400
    M2-ATX-HV
    2005 Honda Civic
  1. "SHWEET" a year later 56k hahahahaha
    By justinwebb in forum Show off your project
    Last Post: 04-22-2007, 10:22 AM
  2. 1 Year experience
    By slimsimon in forum General Hardware Discussion
    Last Post: 05-09-2005, 02:43 PM
  3. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  4. A year on
    By Rob in forum Off Topic
    Last Post: 08-04-2002, 10:24 PM
